How much lift do I have?
Old Aug 21, 2006 | 09:51 AM
Saint_Berzerker's Avatar
Question How much lift do I have?
I know this might sound like a retarded question. But I'm trying to find out how many inches of lift my truck has.
I've had it for about a year and a half, most of that time not running. I've done a lot of work on it.
I didn't ask when I bought it.
Do you just measure the blocks on the rear wheels?
Old Aug 21, 2006 | 10:52 AM
4Runner 4Play's Avatar
Well basically, there are two types of lift. One: Suspension lift. i.e. longer shocks/coils, spacers, shackles. Or two: Body lift. i.e. blocks in between the frame rails and body (d'uh)lol. What you need to see is, do you have blocks? and/or susp. lift. Then you will be able to decipher what your looking at/for. Hope this helps.
Cheers, Lee Hathaway
Old Aug 21, 2006 | 12:05 PM
mastacox's Avatar
I would measure the distance from the ground to the bottom of your body in a couple of places, and then compare these values with someone that has a stock version of the truck. You will then have a rough estimate, and you can look to see if you have blocks between your body and frame and measure those. That will give you a pretty good idea of what's going on.
Old Aug 21, 2006 | 12:10 PM
Flash319's Avatar
If you measure the blocks in the back on the springs it will be close. The only other thing is if they added a add-a-leaf as well as the blocks. If it is ISF front I would bet they didn't as the average lift with blocks in the back is 4 inches. If you want more then that you should get proper springs instead of blocks.
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
