How high do you rev your 3vze :D
Old Jan 7, 2011 | 03:41 PM
  #41
93yotaSR5's Avatar
Originally Posted by 87 4x4
2000-2500rpms when shifting with the 22r. with the cold weather(20-0 F) it seems the power band is wider and from 3500 to 5500 it has alot of go.
didnt the thread say 3VZE, not 22R?
Old Jan 7, 2011 | 03:44 PM
  #42
93yotaSR5's Avatar
Originally Posted by Wheelindealin
Anybody know if you can put a rev limiter in a pickup? the v6. Ive over reved muddin and stuff and would like to set one about 4k or 4500
you can get an msd 6al ignition box, which will allow you to use rpm modules to set your rev limit. i have one in my stang and it works very well. especially when in the rain
Old Jan 7, 2011 | 05:03 PM
  #43
rattlewagon's Avatar
Originally Posted by *yoter*
from my experience it'll never last if you baby it, gotta runner for what shes worth, keep her cleaned out.
We call that an "Italian tune up" haha.
Old Jan 7, 2011 | 08:53 PM
  #44
Wheelindealin's Avatar
Ok cool, it would be sick to hit the rev limit alot haha
Old Jan 7, 2011 | 10:04 PM
  #45
alil2cul4u's Avatar
Originally Posted by 94toyota
x2 on the running like crap when its cold mine is pretty quick off the line i can power slide on dry cold ground from 1st to 2nd i also see it start to pulll hard above 3000 rpm
last week i hit 105 mph on the freeway i don't get why every talks trash about htis engine
I've noticed the same... I can generally hit 100 like nothing on the freeway. I shift anywhere from 3k to 5k depending on the speed limit and who is around. If I'm trying to beat someone from the line ill rev to 3k and go easy on the clutch for a better powerband. That is with the stock tranny and transfer case with 31x10.50x15's on it.. So its not doing to bad..
Old Jan 8, 2011 | 05:11 PM
  #46
93yotaSR5's Avatar
you can also get on the msd website , and they have a rpm dial selector so you can tune your rev limits with a turn of a knob, instead of the rpm modules.
Old Jan 8, 2011 | 05:20 PM
  #47
camo31_10.50's Avatar
i know of a VERY VERY easy and FRREEEEE rev limiter
it's even attached to your body.
it's called YOUR RIGHT FOOT.
if you're revving too high, well DDDDDDDDDDUUUUUUUUUUHHHHHHHHHHHH give it LEESSSS gas ya jackwagon
Old Jan 8, 2011 | 08:34 PM
  #48
thats sweet, im a look into those
Old Jan 9, 2011 | 03:35 AM
  #49
newTOyotas's Avatar
The 3.0 is a dog, IMO. Toyota just puts crazy gearing in their rigs to cover that up.
Old Jan 10, 2011 | 02:41 PM
  #50
94toyota's Avatar
newToyotas i don't have crazy gearing i own a 289 ford fairlane i put 4.27's in the fairlane and its still slower than my truck (4.30's) plus the fairlanes tires are 24.5 inches tall and it has rpm airgap 4 barrel and a midrange cam kit
Old Jan 10, 2011 | 05:45 PM
  #51
newTOyotas's Avatar
IMO (in my opinon) then your fairlane must have issues if it can't at least compare to your truck. My truck is a great little daily driver and gets ~ok~ fuel mileage compared to my last truck(98 ext cab Z71) but I guess I've driven one too many vehicles to relate a 1995 3.0 5spd 4x4 as any kind of a performance oriented vehicle.
As a side note, I have a 1987 monte carlo with the original 305 w/125,000 miles and got it to run a 14.88@91.79 in the 1/4. It was factory rated @ 180hp and ~I believe~ the 3.0 in my truck is 150hp(?) but even though they both weigh within ~100lbs~ of each other, there is NO comparison in performance even though the monte has a much less aggressive 3.73 gear ratio. The truck ~should~ gain some on that 30hp difference considering it has a much more aggressive 4.56 gear ratio, no? I bet my truck would be lucky to run a 19 second flat 1/4 (just a guess, maybe it wouldn't even be able to run that time) and going by the seat of your pants feel, it is a dog(other than that 1200 rpm window that it supports any noticeable gain in acceleration.
Although most any motor has a peak rpm that it makes power at, I like a motor that also at least feels as if it is trying to get out of it's own way at all other rpm ranges. This is just my opinion on the 3.0 toyota motor that was supplied with my truck(which right now 'only' has 121K on it so it's not like it should be completely worn out yet).
Maybe others don't feel as strongly as I do about this same matter, but I have seen enough post 3.slo to know exactly where they are coming from.
My truck does get me back and forth to work, it has a working 4wd system, and it gets better than the ~10mpg~ that my last truck got so I am not at all trying to complain. It does exactly what it's supposed to do. Running performance oriented timeslips isn't one of those things.
Old Jan 20, 2011 | 04:43 PM
  #52
JR's Avatar
JR
Update on how high I rev my 3vze, lots of snow lately here in Alberta with a wind so snow drifts everywhere in the small town (hamlet) that I live in. Breaking trail in deep snow rev that little 3vze to 5K in first and second gear and have not gotten stuck. Girlfriend will not rev her 1992 pickup and when the snow gets deep truck stalls everytime at 2K she has been stuck 4 times even though I broke trail. Neighbour is a mechanic and he too will not rev over 2K in first and second gear, he stalls it everytime the snow gets deep and has got the truck stuck. Guess who has to pull them out everytime. Had to go up a steep hill in the next town, nobody had gone up the hill yet, first gear at 5K snow flying everwhere walked right up. Locals asked if I still had a motor or transmission left, have driven a 1000 miles since then no problems.
So the little 3vze does not mind pulling a few revs, in fact hauls ass when in lower gears and running 4 to 5K.
Old Feb 1, 2011 | 09:40 PM
  #53
ELJEFFEDOR's Avatar
Talking
Originally Posted by phildelfino
With an automatic, my experience varies, and yours might too.
Before with 31x9.50x15 and stock 4.10 axles, I'd get it up there over 4500 or 4700 and it would waver (this with the ECT button on).
After with 35x12.50x15 and 5.29s, I still get it to waver up over 4700 before it shifts with the ECT button on.
Original mileage on original motor, 235,276. I drive sensibly around town but when getting on the freeway, I need the speed.
Reno has alot of hills especially west on I80. I hit the freeway at 3-4 times a month.
WOOOO RENO lol i live in carson. less traffic and hills hahaha
Old Sep 9, 2011 | 05:10 PM
  #54
Motorheadno13's Avatar
Hmm, I noticed some of you guys taking the revs up to redline? My 4runner (5speed) losses so much power after 4500rpms and it hates going above 5k. I did install Thorley headers and a custom intake. Maybe it's running too lean?
Old Sep 9, 2011 | 07:40 PM
  #55
TNRabbit's Avatar
As far as I know, ALL 3vze's had rev limiters @ 6300 rpm.
I rev mine up to 5k frequently.
For those saying they have no low rpm torque, SOMETHING IS WRONG. I replaced a lot of parts on mine this year & saw significant increase in power under 3k....fuel pump, fuel regulator, distributor, TPS.
Old Sep 9, 2011 | 08:50 PM
  #56
ChzSoda's Avatar
Donuts in a dirt clearing, 1st to 4k and 2nd as high as you can go before you piddle yourself... Good times.
Old Sep 27, 2011 | 07:25 PM
  #57
Travman's Avatar
I shift around 3500 on average. At 65 mph I'm pull 4000 rpms in 5th gear.
Old Sep 28, 2011 | 01:54 AM
  #58
sechott's Avatar
To the OP, if you have OE spec drivetrain. You shouldn't have to shift that high driving normal. I believe you have an emissions related problem, the EGR valve would be my first concern. I rarely have to hit 3k RPM, I have the 3vze and manuel 5 speed. I barely have to touch the gas to start going.
Old Oct 2, 2011 | 06:31 PM
  #59
bbrideau's Avatar
Red line all day every day. i have 375,000 KM on mine. KM not miles im in canada Eh.
Old Oct 2, 2011 | 08:02 PM
  #60
bmcghie's Avatar
I run 32x11.5s... with 5.29 gearing. That's what the PO put in, and I think I like it.
4000rpm in 5th gear gives me 84mph... and 16mpg. That's as high as I feel comfortable going for long periods of time. She hasn't let me down yet though, 22 hours solid driving from Bishop, CA to Vancouver, BC, Canada... at 4k. Never missed a beat (leaked 1/2qt of oil though.
In town, I always shift at 3k. 4k to get into 4th. If I'm angry, the Veezy goes to 5-5.5k before I shift.
I find I can hold my speed, with any load, up all but the really steep hills, if I'm above 3000rpm. 3400rpm is supposed to be peak torque...
3.slow? Sure, it can't match a GT-R for speed, but it keeps on going and going and going, at any elevation, any temp. Love it.
