How hard is to change T-stat?
Old Dec 24, 2007 | 11:39 AM
pasha's Avatar
Guys, trying to fix old problem with overcooling. Any of you gurus. How hard is to change T-stat on v6? Thanks for all your help.
Old Dec 24, 2007 | 12:22 PM
seafarinman's Avatar
Easy to do. The thermostat is behind the upper radiator hose neck. Unbolt that neck, and pull out the thermostat and put a new one in. Bolt it back up and top off the radiator. Done.
Old Dec 24, 2007 | 02:13 PM
86tuning's Avatar
IIRC it's at the top of the lower rad hose. 3 nuts and you're done.
Old Dec 24, 2007 | 02:16 PM
thook's Avatar
Gotta drain the coolant first, but it's at the block end of the hose....and it's easy.
Old Dec 24, 2007 | 02:18 PM
4runnerchevy's Avatar
Banned fruitloop
Thermostat
1/2 Banana for the trick!
Old Dec 24, 2007 | 02:24 PM
Yeah your right... haven't changed mine since... 2002? It sure has been a while.
Old Dec 24, 2007 | 02:47 PM
aaronk's Avatar
Just be sure to use a Toyota OE thermostat (probably around $15) and a new gasket.
Old Dec 25, 2007 | 07:35 PM
pasha's Avatar
WoW You guys!
Thanks alot one more time.
Backcountry411
Jul 24, 2015 08:06 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
skoti89
Jul 8, 2015 12:05 AM
