How to get rhino lining off of truck
Old Sep 19, 2011 | 02:56 PM
yotarover's Avatar
trade cab for another one
Old Sep 19, 2011 | 04:07 PM
MYTOYOTA's Avatar
Dude why do you want to take it off? It looks fine judging from the pics you showed us. If it's a weight issue I understand but I wouldn't go through the trouble of removing it all from the ENTIRE cab.
Old Sep 19, 2011 | 04:15 PM
yoterr's Avatar
i dont believe those pics are his...and he said its peeling and bubbling...hence why he wants it gone...im lucky the P.O didint sand under it so if i hit it with the pressure washer it should all come off...most of it came off with regular hose
Old Sep 19, 2011 | 05:44 PM
BUST'EM504's Avatar
I don't think this douche did Either he even left the graphics on the truck. I am going tothe pressure washer soon to try just been busy
Old Sep 19, 2011 | 05:46 PM
  #25
T_F_E's Avatar
Getting the graphics off was the hardest part of my paint job but i tihnk my turned out really good
Old Sep 19, 2011 | 06:22 PM
  #26
91muddog's Avatar
go for a drive through a dense forest trail, trees will do the rest for you
  #27
BMcEL's Avatar
If you're not worried about messing up the paint get a hot blade. It's basically a soldering iron with a flat blade razor attachment and does a pretty good job of removing decals. 30 watts or higher should be fine. Might help with removing any bed liner that actually adhered to the paint too.
Old Sep 21, 2011 | 10:13 AM
  #28
offset442's Avatar
rent a 5,000 psi steam pressure washer and keep it away from the plastic, rubber and glass.............. sounds like a cheap pvc based coating, should melt right off at 240oF and high pressure, other wise you will have to have it blasted with coarse garnet.
Old Sep 21, 2011 | 01:26 PM
  #29
yotarover's Avatar
you can sand blast the whole truck. it works just cover what you don't want to blast.
Old Sep 21, 2011 | 04:51 PM
  #30
Nervo19's Avatar
Harbor Freight 14.99
"hot blade decal remover."
http://www.harborfreight.com/hot-bla...ver-65057.html
Ichneumon
Sep 27, 2015 04:21 PM
jjrbus
Jun 27, 2015 12:56 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
