How do you know a motor mount is broken?
Old Jun 26, 2008 | 11:31 AM
  #41
Lysmachia's Avatar
Originally Posted by dirtoyboy
So what ended up getting the pilot bearing out finally? I usually use a piece of sandwich bread
Sammich bread huh? We've heard wet newspaper. For future reference (since we've had to grind it out 2x) how the hell do you pull that POS without using a Pilot bearing puller that NEVER works...?
Originally Posted by Brenjen
Well if I was there I'd pull it for you so you could have a break from it; but since I'm not & virgins are hard to find...Good Luck.
You are a saint. I'll cook a feast for you! For anyone.... LOL Even a virgin!
Old Jun 26, 2008 | 12:36 PM
  #42
Lysmachia's Avatar
Oh you got to be kidding me! CAN'T GET TO TROY'S BOTTLE JACK. GOING AFTER MINE....
Old Jun 26, 2008 | 04:50 PM
  #43
tc's Avatar
tc
Well, I'm guessing if you can lift the wheel off the ground by the oil pan the motor mounts are OK ... bummer - the search continues ...
Old Jun 26, 2008 | 05:15 PM
  #44
BLKNBLU's Avatar
Originally Posted by Lysmachia
If only I could turn a screw driver with my thighs I'd be all set! (Don't get any ideas guys!!)
How can we not? (get ideas)
Old Jun 26, 2008 | 05:48 PM
  #45
Brenjen's Avatar
Just curious; did you have eyes on the mount when it lifted? It may be busted but still connected. I've seen some mounts that have a hook & loop design where the sheet metal is sandwhiched around the rubber insert which is bonded to the sheet metal. Hard to explain but the ends have little hooks & will keep the mount in one piece even if the rubber fails. I imagine you did though; it's a stab in the dark.
Old Jun 26, 2008 | 08:29 PM
  #46
tc's Avatar
tc
Damn 3.0, I don't know how you can possibly see the motor mounts without disassembling the truck ...
Old Jun 27, 2008 | 06:27 AM
  #47
Brenjen's Avatar
It is shoe horned in there - I feel your pain. I have an oil leak on the passenger side & I don't feel like taking off the intake plenum just to change a freakin' valve (cam) cover gasket.
Maybe you can look at a new stock motor mount & see if it has any way possible to lock together when the rubber is toast? I have never seen a Toyota motor mount so I can't say. If not then you know the mounts are good; but if it has that configuration where it can lock together you may need to get a dental mirror or two & a helper & look again.
Old Jun 27, 2008 | 08:59 AM
  #48
Lysmachia's Avatar
We do have the dental mirror..... It's worth a try. This is where a SA setup would make it a lot easier to see stuff I suppose. (From underneath that is)
Old Jun 27, 2008 | 09:02 AM
  #49
Brenjen's Avatar
I just went out to put on my Sonoran Steel truss & my tranny cooler & I discovered a couple things. First off the motor mounts are easily visible from under the front of my 4Runner w/ the 3.0 - secondly, my crappy autozone cv's that I just put on a few weeks ago have blown the boots & slung grease everywhere.
I guess I have to drop my own diff again today; might as well do it & armor up the ARB line that's touching my oil pan & block while I'm under there. I think you guys jinxed me.
Old Jun 27, 2008 | 02:01 PM
  #50
Lysmachia's Avatar
The Demon Jinx of Ron Strikes AGAIN!!!
Old Jun 28, 2008 | 12:22 AM
  #51
thook's Avatar
I was gonna say....a mirror. I have an extending one with a flex head I use more than I thought I would when I got it. Pretty handy.
Old Jun 28, 2008 | 08:39 PM
  #52
Lysmachia's Avatar
Normally it is handy, but atlas... the motor mounts are ok. But seriously guys, thanks for the diagnostic support!!!
cars-guy
Aug 16, 2020 06:59 AM
Scotto6591
Sep 1, 2015 03:24 PM
keithporter83
Jul 24, 2015 07:37 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
jon.r
Jul 11, 2015 03:34 PM
