How do you check the fan clutch?
Old Aug 27, 2009 | 04:31 PM
wurmy77's Avatar
Can someone please tell me how to check my fan clutch to make sure its ok. I have been running hot the last few days. I replaced the thermostat and burped the system after a flush and refill. I just bought the truck so I am not sure how loud the fan should be when its fully engaged.
Old Aug 27, 2009 | 05:04 PM
abecedarian's Avatar
with the engine warmed up and turned off, try to spin the fan by hand: grab a fan blade and try to spin it. It should spin less than 1/4 turn or so before coming to a stop after you release the fan blade. If it spins more than that it's bad.
Old Aug 27, 2009 | 05:11 PM
wurmy77's Avatar
LOL It's Bad it will spin 1.5 revolutions
Old Aug 27, 2009 | 05:16 PM
probably.
Mine won't spin 1/2 turn when the engine is cold (~70F). Which, ironically, might mean mine is bad too since it should freewheel a bit when cold.
Old Aug 28, 2009 | 02:41 AM
TNRabbit's Avatar
a turn & a half is BAD~
Old Aug 28, 2009 | 04:44 AM
poynter's Avatar
I gotta go check mine out, I've been chasing a squeel that I cant seem to locate.
Anyone know if a bad clutch fan squeels?
Old Aug 28, 2009 | 05:32 AM
TNRabbit's Avatar
*deleted* dupe post
Old Aug 28, 2009 | 05:39 AM
TNRabbit's Avatar
Only if it's a paid informant... It's most likely one of the idler pulleys for the timing belt, or the bearing behind the fan clutch.
Old Aug 28, 2009 | 06:01 AM
poynter's Avatar
Mines a 22re so no t-belt. I guess I'm going to start with the tensioner a the top since it looks easiest.
the1998sr5
15
Jul 14, 2020 08:35 PM
coryc85
Sep 9, 2015 06:24 AM
PlayAwhile
Jul 20, 2015 11:36 AM
jackiebrownia
Jul 20, 2015 09:02 AM
1996Taco
Jul 20, 2015 12:02 AM
