How difficult to change leaf springs
Old Jun 27, 2006 | 01:03 PM
ReneB64's Avatar
How difficult is it to change the leaf springs on a 1993 toyota 4x4 ext cab? Am considering OME 18 and was thinking of doing it myself.....
Old Jun 27, 2006 | 01:23 PM
BeaterToyota's Avatar
In theory it's super easy:
1) Jack up truck by the frame and support it so the suspension drops all the way down.
2) Remove u-bolts
3) Remove shackle bolts and spring hanger bolts.
4) Installation is the reverse.
In practice, it's usually a lot harder because the bolts tend to seize up with the sleeves that are inside the bushings, and a lot of times they have to be cut out. Also, old rusty u-bolts can be a pain, so just buy new ones and cut the old ones off instead of trying to reuse them.
Since you're in CA you may not have any problems with this stuff, but I've only wrenched on east coast rigs and the rust sucks.
Old Jun 27, 2006 | 01:24 PM
snap-on's Avatar
you jack the truck up... support it, put the jack under the axle, then undo a few bolts and your good to go.
rust will complicate matters but really no big deal. I did mine by myself in about 1.5 hrs.
Old Jun 27, 2006 | 03:44 PM
kyle_22r's Avatar
the worst part is always getting the spring pins out. the shackles aren't so bad, but the pins for the front hanger are almost always stuck to the bushing.
ReneB64's Avatar
Thanks, am willing to give it a shot...will let you know how it went.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
shisha1999
Sep 21, 2015 08:22 PM
_Nicco_
Aug 28, 2015 07:26 PM
Nickdigg
Jul 7, 2015 06:04 AM
