How to connect these tubes??? 91 Pickup 2.4L
Old Jan 15, 2016 | 07:40 AM
vikecowboy's Avatar
I am finishing up a head gasket repair and am trying to figure out how to connect these tubes. I thought I had them connected correctly but came across a picture online that showed differently. See the photo I took.
The orange ones goes underneath the EFI, the green one goes way left and connects to the top of the black canister (can't remember what it is called), and the blue one connects to a part on the fuel bar (also can't remember what it is called. (maybe a fuel pressure regulator??)
They all have to connect to the end of the black metal tube thingy that runs the length of the head. However my tape marking on the metal bar fell off so I am not sure what goes where.
Any ideas?
Attached Thumbnails How to connect these tubes??? 91 Pickup 2.4L-22re-tub-connections.jpg
Old Jan 17, 2016 | 06:27 AM
vikecowboy's Avatar
Found a Vacuum drawing that shows the connection from the canister goes to the Throttle Body so will trace that connections through the metal piece and figure that one out. Hopefully the others will match the drawing I found online.
File Type: pdf
mgklee
Nov 23, 2015 10:41 AM
whiseje
Nov 6, 2015 04:30 PM
kanyonkritter
Nov 6, 2015 07:18 AM
towotaguy
Nov 5, 2015 08:05 PM
Runnin13s
Nov 5, 2015 07:45 PM
