Horrible noise from.... Gauges?!?!? (video inside)
Old Dec 11, 2006 | 12:43 AM
rcm3's Avatar
It seems to happen only when its well below freezing and gets better/goes away as it the heat warms up the interior.
Its definitely coming from directly in front of me and seems to be around the gauges because when I push around that area it changes the noise. I demonstrated pushing on the dash in the video.
Also the speedometer needle seems to vibrate as the noise worsens.
Let me know what you think. Thanks.
Old Dec 11, 2006 | 02:01 AM
Elton's Avatar
speedo cable also that would drive me nuts but im sure my stereo will drown it out
Old Dec 11, 2006 | 02:08 AM
ChickenLover's Avatar
Definitely the speedo cable.
Old Dec 11, 2006 | 06:30 AM
MMA_Alex's Avatar
try lubricating the spedo cable. if it still does it then it should be replaced, but it cant hurt to try lubing it first.
Old Dec 11, 2006 | 08:44 AM
rcm3's Avatar
Thanks for the diagnosis....
Got any write-ups or direction for how to lube it or get to it? Or is it pretty self-explanitory?
Old Dec 11, 2006 | 09:00 AM
spudrunner's Avatar
It's pretty easy, just did mine. Go to Napa and get the dry graphite spray in the aeresol can. Here's a link that may help you.
https://www.yotatech.com/forums/f115/doing-sr-5-gauge-cluster-swap-how-pictures-51800/
Old Dec 11, 2006 | 07:04 PM
trythis's Avatar
Sounds like you have 43 goats bleating at once in you truck.
I did the same thing, tried to lube mine and that worked for 3 months, then the noise came back. I tried a cheap $20 napa cable that lasted 2 weeks, then it started screaming! I eventually went to a speedometer shop to get one made. that cost $30 Toyota wants $90 for my year and model.
Old Dec 11, 2006 | 07:17 PM
CJM's Avatar
CJM
You sure said it..
Mine clicks at lower speeds and when the engine and outside is cold..radio just drowds it out. I would lube it, but dont feel like taking my dash apart. Try using silicone spray next time too.
Old Dec 11, 2006 | 07:44 PM
spudrunner's Avatar
If you decide to lube it do yourself a favor and get the dry grapite spray. You don't want to gunk it up with silicone, wd40 etc.
Old Dec 11, 2006 | 07:59 PM
drew303's Avatar
hey nice driving gloves =P
Old Dec 12, 2006 | 06:32 AM
gregbreakseverything's Avatar
Every toyota truck I have owned has done that. Mine recent truck started some of the preliminary signs a cuple weeks ago. If anyone knows how to lube the speedo cable, that would be helpful.
Old Dec 12, 2006 | 04:57 PM
rcm3's Avatar
Bleeding goats indeed....
I guess I'll just go the replacement route. I would hate to have to tear it apart again and risk screwing things up twice.
And while I'm in there I can remove the dead spider from right side of the gauge container. Sweet.
Thanks for the help!
Old Dec 13, 2006 | 03:34 PM
nmtoy's Avatar
I just lubed mine today. I used a lube called Dry Slide Bike Aid.
I use it at the bike shop to lube cables. It has a needle applicator so you can get it into the cable.
Here is a link http://www.russack.com/view_product....39b68934fa4b65
Hope that helps!
Robb
Old Dec 13, 2006 | 04:39 PM
spaceycayce's Avatar
NMToy, wanna do mine when I get it back. If its really easy to do I may just do it when i take apart the dash for locker switches and new speakers.
I should be getting her back from surgery soon I got a written date of Dec 20th.
Old Dec 14, 2006 | 09:55 AM
nmtoy's Avatar
Spacecayce,
If you need some help let me know, it's about a 1/2 hr job.
Robb
Old Dec 14, 2006 | 10:24 AM
Diesel_Freak's Avatar
mine (gen1) does that too... not in awhile but it's done it
Old Dec 14, 2006 | 10:27 AM
drew303's Avatar
Mine just started the other day.. just a bit when i hit over 30mph... I swear its because I read this thread!!! damn you !
did it for a bit, but now its gone again =/
Least now i know what that damn goat noise is comin from!
Old Dec 14, 2006 | 10:33 AM
da_bigg_wigg's Avatar
Mine will do it, but it rarely lasts longer than 5 seconds and it only happens when it's cold out when you start the truck up. Then it fixes itself. I love it when the truck does that...
Old Dec 14, 2006 | 10:51 AM
sts2usnss's Avatar
Mine does it to but only when it's freezing outside. like everyone else, onse it warms up its all good. I know its coming from the speedo cable but didn't know you could lube them. Is there a way to do this without taking the entire dash apart?
Old Dec 14, 2006 | 11:53 AM
nmtoy's Avatar
You only need to take the drivers side apart.
