horn stuck on
Old Jan 8, 2008 | 02:39 PM
dubweiser's Avatar
horn stuck on
well....my horn on my 89 4runner didn't work..so i decided to add a set of air horns to get rid of that dinky little thing they give you from the factory, so anyway i get to hooking it up, then put on the last connection to the relay and BAAAAAAAAAAAAAAAAAAAAAAAAAAP.....horn blasts my eardrums out, so started to look into it a little bit, come to find out the horn is always hot, like the button in the steering wheel is stuck
...is this something that is common ? anyone else have a similar experience to help ease my troubleshooting ?
Old Jan 8, 2008 | 03:36 PM
Elton's Avatar
sounds like u got the wiring mixed up did u use a relay ?
Old Jan 8, 2008 | 03:50 PM
rowdy235's Avatar
not sure what truck, but on mine the horn has constant 12v and the other side is grounded via the steering wheel. Could you tell us how you wired it?
Old Jan 8, 2008 | 04:01 PM
dubweiser's Avatar
wired it thru the provided relay......i am pretty sure i screwed up if it is supposed to be hot all the time and the ground is provided by hitting the horn, i'm gonna try just using jumpers from the old connector to the compressor tomorrow....i couldn't find the old manual to check if one side was hot all the time
i'll let you know how i make out when i get my hearing back
Old Jan 8, 2008 | 04:13 PM
4runnerchevy's Avatar
Banned fruitloop
Relay
Sometimes a relay will have a N.O. (normally open), and a N.C. (normally closed) contacts, you should be on the N.O side.
Old Jan 8, 2008 | 06:02 PM
dubweiser's Avatar
all it gave for the relay was some shoddy instructions and directions that make no sense at all, i'll take a look at it when i'm a little less tired and its a little less wet out
Old Jan 8, 2008 | 08:50 PM
rowdy235's Avatar
alright, I'll have to make a couple assumptions here
Lets say you have the trucks horn just disconnected. Lets also say you have a SPST relay (with 4 poles). This is how it should be wired up to the best of my knowledge:
Redeth005
Jun 28, 2018 08:16 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
spiewaker
Dec 16, 2015 01:10 PM
Obmi
Sep 24, 2015 08:10 AM
xzen73x
Sep 14, 2015 03:00 AM
