horn stuck on
horn stuck on
well....my horn on my 89 4runner didn't work..so i decided to add a set of air horns to get rid of that dinky little thing they give you from the factory, so anyway i get to hooking it up, then put on the last connection to the relay and BAAAAAAAAAAAAAAAAAAAAAAAAAAP.....horn blasts my eardrums out, so started to look into it a little bit, come to find out the horn is always hot, like the button in the steering wheel is stuck
...is this something that is common ? anyone else have a similar experience to help ease my troubleshooting ?
wired it thru the provided relay......i am pretty sure i screwed up if it is supposed to be hot all the time and the ground is provided by hitting the horn, i'm gonna try just using jumpers from the old connector to the compressor tomorrow....i couldn't find the old manual to check if one side was hot all the time
i'll let you know how i make out when i get my hearing back
alright, I'll have to make a couple assumptions here
Lets say you have the trucks horn just disconnected. Lets also say you have a SPST relay (with 4 poles). This is how it should be wired up to the best of my knowledge:
spiewaker
Dec 16, 2015 01:10 PM
Obmi
Sep 24, 2015 08:10 AM
