Horn Relay Location [picture]
Old Jul 16, 2012 | 01:28 PM
adamthedroog's Avatar
Where is the horn relay?
Old Jul 16, 2012 | 01:49 PM
DeathCougar's Avatar
Should be under the hood, not under the dash
Old Jul 16, 2012 | 02:21 PM
Sorry I forgot to state the year. Would that be true for a 1990?
Old Jul 16, 2012 | 02:56 PM
myyota's Avatar
If your horn isn`t working check the contact under the steering wheel.
Old Jul 16, 2012 | 02:59 PM
I did and it's fine. I need to check the relay.
Old Jul 16, 2012 | 03:37 PM
MudHippy's Avatar
Possibly here...
According to this...http://personal.utulsa.edu/~nathan-b.../2powersou.pdf
Or maybe it's not even shown in the pic above?
Old Jul 16, 2012 | 04:12 PM
That's what's got me confused the green box is the starter relay but all of the FSMs that I've looked at not only says that that should be the backup relay it doesn't even say where the starter relay should be at all.
Old Jul 16, 2012 | 04:52 PM
myyota's Avatar
Did you check the horn it self ?. I had the horn on my 86 4Runner go bad,
Old Jul 16, 2012 | 07:02 PM
I don't know how or why but it's working now. Thanks for all of your help.
Old Jul 17, 2012 | 10:29 AM
Stuwy123's Avatar
The contact in the steering wheel can be the culprit but also the circuit goes through the actual column.
Blast the bearings on the steering shaft (in the dash) with WD-40 to clean the crud out. My horn slowing died on me, turned out to be crud in the bearings.
Old Jan 26, 2022 | 07:28 AM
Smokintires137's Avatar
Did you ever solve?
Attachment 192036
I'm working on the same issue with my 90 4runner. Everything I've found shows a relay attached to that white panel, about half way up. I can see that you have the same setup as mine (no relay clipped on). Did you ever get to the bottom of this? My switch is good, fuse is good, horns are good. No honk. Thanks!
Old Jan 27, 2022 | 07:39 AM
BigBluePile's Avatar
Well, it's been 10 years so.....
....usually it's the contacts in the steering wheel.
Old Jan 31, 2022 | 10:53 AM
RAD4Runner's Avatar
Horn Troubleshooting:
https://www.yotatech.com/forums/f116.../#post52381275
grue
Nov 2, 2021 10:41 PM
RAD4Runner
May 18, 2020 01:34 PM
Bryan4x4
Feb 10, 2017 09:31 AM
Kiroshu
Apr 16, 2016 03:07 PM
stevec8720
Sep 9, 2013 07:18 AM
