Home alignment- caster question
I am about to go through all of this myself, but last time i had enough trouble with tie rods to take the whole thing to a shop. They did a crappy job.
I broke a T-bar bolt while installing Downey torsion bars a couple of years ago. The top of the bolt went through the floor of my truck. I actually had to get it out from the top side (under the seat). there is a hole there to this day. I would call that a little risky. Penetrating lube made the other side much easier to deal with.
Great thread. I'm interested to see how this turns out for you.
Alright, the alignment isn't too hard to do, but I realized both tierod ends between 1/16" to 1/8" of play. So after that, I stopped stressing about 1/32"s
Setting the caster and camber isn't too hard, and the toe-in is only "moderate", made a little more difficult by to the worn out rod ends.
I have the pics for a write up, might do one.
Setting the caster and camber isn't too hard, and the toe-in is only "moderate", made a little more difficult by to the worn out rod ends.I have the pics for a write up, might do one.
I think you should do a write up on this. I think it would make a good one...just my opinion..
the1998sr5
15
Jul 14, 2020 08:35 PM
pyramid
Jul 29, 2015 06:53 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
