hole in transmission? (picture)
Old Aug 12, 2016 | 01:18 PM
87truckdude's Avatar
i was crawling around underneath my 87 pickup inspecting everything i should have inspected before i bought the vehicle in june... but i didn't know what to look for then (i knew basically nothing), and have been studying like crazy on this forum (awesome), youtube, manual, etc since then and now i'm trying to get a real assessment of where i'm at with this thing. so in the (perpetually ongoing) process, i curiously start wiping away some of this clearly leaking-from-somewhere oil off the transmission and i find what looks like a hole in the metal??? it does not look like it's supposed to be there. can anyone help me understand what is going on and what the consequences might be? i'm hoping someone will say "oh that's a oem factory hole" but i doubt it
Old Aug 12, 2016 | 01:30 PM
millball's Avatar
If it's directly, on the middle bottom, its supposed to be there.
Old Aug 12, 2016 | 01:34 PM
thanks!!!! i was worried and couldn't find any pictures of the bottom of the transmission anywhere for some reason to compare. i'm going to relax now... on to the other 15 things that actually need addressing! muchas gracias
Old Sep 6, 2016 | 05:18 PM
gsp4life's Avatar
The hole is so oil doesn't pool inside the bellhousing, but the leak still needs fixed. Can you tell if it's engine or gear oil? Engine oil is probably from the rear main seal, gear oil from input shaft seal or the cover.
Old Sep 19, 2016 | 02:40 PM
acudadude's Avatar
Dont forget to ck the gear oil level in the trans
Sustainobile
Oct 5, 2023 07:50 PM
surf4life
Nov 30, 2019 01:38 PM
colinmil
Aug 28, 2016 10:04 AM
93RedKrawler
Jul 17, 2016 09:11 AM
shedhunter32
Jun 22, 2016 07:59 AM
