Hmmm...seems TPS does affect MPG on 3VZE
Old Dec 5, 2005 | 10:46 AM
nrgetic99's Avatar
A while back, I accidentally did a 230 mile round trip in my 3 slow M/T with the TPS disconnected.
The trip was 90% highway where I ran 65 to 75 mph ( 72 most of the time) and the 10% was b roads and some climbing upto a ski resort in the Blue Ridge mountains.
I got 15 mpg round trip.
Did the same trip Saturday with the TPS reconnected and at least 3 tanks of a prototype injector cleaner in the system.
I got nearly 30 miles more out of the tank of gas which means I got nearly 2 mpg better. 2mpg is not bad but for me but an extra 25 to 30 miles on the tank means I can get there and back ( I work part time at the resort) without stopping for gas which is nice.
So, a properly functioning TPS clearly impacts mileage. Poor gas miles ? Check your TPS.
David
Old Dec 5, 2005 | 11:36 AM
4Crawler's Avatar
No surprise, as noted on my TPS web page:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
"Symptoms of a bad or mis-adjusted TPS include:
* Varying idle speed
* Hesitation while accelerating
* Poor fuel economy
* Inability to correctly set base ignition timing"
Old Dec 5, 2005 | 11:50 AM
Fink's Avatar
Yeah, that happened to me...mine was shot and I spent about 2 weeks replacing stuff and cleaning stuff to help my mileage, finally surrendered and took it to the dealer and they said, yeah you just need a new TPS...
Fink
Old Dec 6, 2005 | 09:56 AM
TheTank's Avatar
Hey Fink,
what were your symptoms before you started trying to fix the problem? MPG before and after replacing the TPS? I'm having a big problem with gas mileage. Granted, I have 33's but I also have 4.88's and the engine runs ok, but I can watch the gas gauge drop dramatically on very very short trips (even if I keep the RPMs really low and drive like a grandma). It just seems like its dumping fuel into the engine for no reason, and there is sometimes that slight hesistation when getting going like if gets flooded and then it will go. Think this sounds like my TPS going?
Old Dec 6, 2005 | 10:06 AM
4Crawler's Avatar
Easy enough to test the TPS to see if it is working OK or not:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Dec 6, 2005 | 12:03 PM
nrgetic99's Avatar
Agreed.
Rogers site covers a lot of stuff. My TPS was slightly different and in the end, the easiest way for me to check was to look at the pin voltages at the ECU.
That was when I dsicoved that I was not gettting a WOT voltage.
David
MadMax48
Mar 3, 2020 10:33 AM
Longbed 90
Mar 11, 2019 12:38 PM
kawazx636
Sep 29, 2015 08:22 AM
larrys93pickup
Sep 17, 2015 07:05 PM
