High Idle=More use of gas..Need advice
Old Oct 6, 2010 | 01:57 PM
Myron's Avatar
Guys,
So this is where im at. I adjusted my idle valve screw.
When im sitting at a light or just letting it idle..there is no surging...just a really high idle..This doesn't happen all the time..I notice this more when ive been driving for a while when its hot. I did check the vacuum lines and didnt see anything on there..Im actually going out there in a little to spray some soapy water around the vacuum lines to make sure im not missing anything.
Last night i filled up a full tank of gas..drove not more than 60 miles and now im just above Half tank..We all know thats just insane..and the funny thing is i dont have a heavy foot.
I did run sea foam thru my system a few months ago..maybe i should run it thru it again???
Any help or advice will help me out since im lost at this point.
Old Oct 6, 2010 | 02:20 PM
yotaman90's Avatar
Are you sure you really used that much fuel? It could be that the sending unit in the tank went bad. I know on my truck once I drive about 60-70 miles my gas gauge goes straight to E, but I know that I haven't used that much gas in such a short time. Also, which engine? 22R or 22R-E?
Old Oct 6, 2010 | 02:58 PM
Teuf's Avatar
I would set your timing, and make sure you have a 190 degree Thermostat. I had a cooler one and seamed like it confused the idle. I got the toyota dual stage Tstat.
Old Oct 6, 2010 | 05:33 PM
jason22's Avatar
what motor? i have the 22re and had a high idle as well. i found that there is a little plastic piece that is connected to the diaphram on the throttle in the intake. the plastic piece was clogged. i removed it and idles perfect. good luck
Old Oct 6, 2010 | 05:43 PM
myyota's Avatar
Remove the throttle body and give it a good cleaning and make sure the vacuum ports on it arn`t plugged.
Old Oct 6, 2010 | 06:03 PM
coops2k's Avatar
mine started this 2 days ago, so I feel your pain.
when I can, will check for a vacuum leak, since nothing has changed or been done to the truck.
Old Oct 6, 2010 | 08:48 PM
Myron's Avatar
I have the 22re..I know that when i drive the guage tends to fluctuate but i know for a fact that i am using that much fuel..coz one day i ran out of gas LOL
i did check the vacum lines they seem fine..the next step is to take out the TB and give it a cleaning.
Eggslinger
Jun 8, 2019 03:32 PM
kcaudill
Jul 20, 2015 12:06 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
ZONAYODA
Jul 13, 2015 07:17 PM
