Hi from Oregon
Old Mar 29, 2013 | 06:53 PM
Levi Huff's Avatar
Originally Posted by Co_94_PU
A bad weld will come off with some hammer and chisel work, A good weld and it'll still be there long after the other metal has broke/torn
There is a special tool, pipe cutter. If you canget your hands on the chain type they're much easier to work with in the cramped spaces.
You'll likely also need a flaring tool to get it all back together.
if i cut it off to weld the glass pack on do i need to remove my gas tank and battery before welding or what? ive never welded on a car or truck
Old Mar 29, 2013 | 06:59 PM
Co_94_PU's Avatar
You need to pull the pipes off the down tube, andthe assembly off the truck. No way you can get the top portion with it mounted.
Old Mar 29, 2013 | 07:04 PM
Levi Huff's Avatar
what?? haha still tryin to figure all this out lol
Old Mar 29, 2013 | 07:10 PM
Co_94_PU's Avatar
http://www.utoyot8.com/Picture.aspx?...ppName=MAB368G
Find the first set of connectors toward the front of the truck that aren't welded and are forward of where you want to insert the new bits. Disconnect it, wiggle it out, cut it weld it and put it back. Might be a good idea to source some flanges so you don't have to pull all back out at some later date.
Old Mar 29, 2013 | 07:15 PM
  #25
Levi Huff's Avatar
ill have to pull it off at the cadilik coverter i may jus replace that hole section and straight pipe it
Old Mar 29, 2013 | 07:21 PM
  #26
Co_94_PU's Avatar
Yeah something like that. Mine is stock, solid all the way to the down pipe(left hand bit in the diagram). Fortunatly it's hating colorado and rusting out, by the time I get around to it it should come off with a little kick and tug
You can make those cuts with a hacksaw once it's on the bench easy enough also, but it's usually done with the pipe cutters.
Old Mar 30, 2013 | 01:48 PM
  #27
Levi Huff's Avatar
there is a loop thing thatholds it up so it wont sage they welded the ppipe to that and welded some of it to the muffler so gonna have to loose an inch of pipe or so no biggie haha doint that tomorrow today im cuttin my doors to put speackers in and hookin up my stereo..
Old Mar 30, 2013 | 01:57 PM
  #28
Co_94_PU's Avatar
Noooo, why ruin a door to put in a speaker just get the size that fits.
Door card 50-100$, Door 150-250. Then x2. You're hurting your resale value and offending purists Bottom line I'd never cut a door panel much less the door.
There are plenty of good 4" that will fit the factory dash speaker boxes.
And now to be helpful.. The 4runners have a pretty decent powered rear speaker setup, it's what I use in mine behind the seats. And a set of 5" fit in my dash with a little wiggling.
Old Mar 30, 2013 | 02:21 PM
  #29
Levi Huff's Avatar
ill check out the rears lol but i like my music loud got to have door speackers
Old Mar 31, 2013 | 09:10 AM
  #30
Levi Huff's Avatar
i decided against door speackers instead imbuildin a box thats removable
IntoTheVoid
Oct 24, 2015 04:54 PM
dropzone
Sep 13, 2015 11:18 AM
dropzone
Aug 11, 2015 05:16 PM
58rennur4
Aug 4, 2015 08:49 AM
