help with truck bogging out in 4 hi
Old Jun 28, 2009 | 03:04 PM
87toyy's Avatar
i've got an 87 pickup carbed 5 speed, and anytime i put it in 4 hi it bogs out. put it in 4 lo and works fine. anyone have any idea what could be causeing this?
Old Jun 28, 2009 | 03:28 PM
Junkers88's Avatar
Do you mean when you wheel it in 4hi it bogs down but doesn't when you drop it in 4lo and try the same trail/line/climb/mud hole/etc?
What size tires and what gears are you running?
Old Jun 28, 2009 | 04:47 PM
kenbo53's Avatar
if ur offroad just 4 low i cant stand wheeling in 4 high. low range gives u so much more control and is alot easier on your clutch
Old Jun 29, 2009 | 05:28 AM
87toyy's Avatar
yeah even when i'm in my driveway in 4 hi which is flat and kinda down hill can barely get the truck to move. it only has 4.10's with 32's. the problem is with low is when i put it in second gear its knocks it out of 4 lo. i dunno if has something to do with the body lift or if theres somethign wrong with the shifter.
Old Jun 29, 2009 | 05:35 AM
Ardent's Avatar
4.10s and 32's isn't your problem. Something else is going on. I would go with your guess about the Body Lift.
Old Jun 29, 2009 | 07:32 AM
87toyy's Avatar
i can see the body lift being the problem with the shifter i'm gonna work on doing something with that, but not the bogging out. i think when i bought it in the winter i had it in 4 hi to drive it home cause it had slicks on it and i dont remember having any problems. and i'm sure recently out fishing and stuff i may have had it in,but it could have been in lo. the only thing i've done with it recently is replace the head gasket but i cant see that having anything to do with it either. i even put it in 4 hi with the hubs in the free position and it still bogs out.
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
Badger62811
Jun 26, 2015 09:26 PM
Robinhood150
Aug 8, 2002 05:57 AM
