Help with speedometer cable removal-trans end
Old Jan 27, 2013 | 11:46 AM
TURBOrunnerNM's Avatar
hello all, I'm in need of some assistance. I'm in the process of trying to fix my speedometer and I have the instrument cluster unscrewed. However, I know I need to remove the cable at the trans end in order to get enough slack on the cluster to slide the cable out. My problem is that I can't get the actual cable out of the driven gear area. I removed the 12mm retaining bolt and popped out the cable sleeve with the o-ring attached. Now the cable itself is stuck and I don't want to break anything. Anyone have any advice? I'd really appreciate it.
Old Jan 27, 2013 | 03:36 PM
Co_94_PU's Avatar
Can you get some pictures.
Not sure you disconnected just the cable. It should be a (about) 22mm knurled ring on the end of the cable to the sensor?
This thread, and this picture. tells me you've disconnected the sensor not the cable.
Old Jan 27, 2013 | 04:25 PM
thanks for the reply man! Here are a couple of photos:
1. Speedometer cable bracket before removal
2. After removal
Thanks for any help you can give me!
Old Jan 27, 2013 | 04:28 PM
Toyota~Boy's Avatar
You need to unscrew the cable from that sleeve. It's the rounded grooved thingy that you touching in the second pic.
Old Jan 27, 2013 | 04:54 PM
so is the speedometer cable the one in the picture you referenced? it looks like i may have been focusing on the wrong thing? the cable i'm disconnecting is at the driver's side of the trans while the cable you showed a picture of is at the rear of the t-case. which one is the actual speedometer cable?
Old Jan 27, 2013 | 05:12 PM
Toyota~Boy's Avatar
If you are 2wd then it's at end of tranny. If your 4wd it's in transfer case
Old Jan 27, 2013 | 05:35 PM
thanks for your help guys. i found the correct cable for the speedo and checked the gear, which was fine. now it's a matter of snaking the cable out and it's off to the parts store..
jasonty
41
Dec 23, 2018 01:00 PM
altydog
Jul 28, 2015 10:20 AM
CanRunner
Jul 20, 2015 01:29 PM
TammyMarie
Jul 15, 2015 11:14 AM
wilbertd
Jul 6, 2015 07:39 AM
