Help removing the chunk
Old Jul 28, 2007 | 11:31 AM
My954Runner's Avatar
OK, 1995, V6 sr5 4WD.
I have all the bolts undone......the ABS sensor out, and I still can't get the thing out.....
Is there a secret to this....?
I can get the passenger side to pull out a little bit, but it seems stuck on the drivers side of the chunk....it doesn't want to move at all......
so what can I do? whack it with a hammer?
work it back and forth?
help!
Old Jul 28, 2007 | 11:33 AM
Kaleb's Avatar
By chunk do you mean the differential, or the axle assembly? If you mean the differential, then you need to pull out you axles about 4-5 inches in order for the differential to come out.
Old Jul 28, 2007 | 11:38 AM
Axles are out already......should be nothing to hold it in unless it has been hit with Locktite at some point....
And yes, I mean the differential....
Chad
Old Jul 28, 2007 | 11:41 AM
waskillywabbit's Avatar
Is there RTV around it or a paper gasket? Might just need some gentle persuasion if it was RTV'd.
Old Jul 28, 2007 | 11:42 AM
Kaleb's Avatar
Is the seal broken? If not then take a razor blade and cut between the diff and the axle housing.
Old Jul 28, 2007 | 11:49 AM
89-4Runner's Avatar
mine had some rust/dried salt around a couple of the studs and wouldn't come free without a little persuasion...
Old Jul 28, 2007 | 11:50 AM
Well, i guess I'll get my Craftsman deadblow (AKA Little Persuasion) out and into the game......
Chad
Old Jul 28, 2007 | 01:03 PM
GOT IT!!! Finally .....
thanks everyone....
Old Jul 28, 2007 | 01:15 PM
Now guess what.....I fonally get the differential, I get the new one ready, get out my oil, and know what I forgot ......
no gasket......
oh well, I will have to get one MOnday....
Old Jul 29, 2007 | 06:19 AM
no gasket......
Dude, just go to the local auto parts place and get some RTV. Those gasekts are a PITA anyway.
Where in Alabamee are you?
Old Jul 29, 2007 | 09:41 AM
ovrrdrive's Avatar
Mine was corroded on there pretty well too. I had to beat, chisel, beat and chisel some more to break it free.
As for gasket, I used black Permatex on it and it hasn't leaked a drop.
Old Jul 29, 2007 | 12:06 PM
I had thought about using Permatex, just wasn't really sure.....
I am in Huntsville, up by the TN state line......
Old Jul 29, 2007 | 01:03 PM
geTBeNt2NIghT's Avatar
I usually just put a jack under the pinion and go up lightly on the jack untill the seal breaks. Makes it super easy
Old Jul 29, 2007 | 03:26 PM
Talking
Well, first of all,
I got my differential replaced.......
with a lot of help from everyone here....
thanks for the advice and answering my newb questions.....
Thats why I like this board!!!
again thanks.....
Its really nice cruising in my 4runner with no howling noise in the background....
1uzRunner
63
Nov 10, 2018 03:58 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
gp66
Sep 7, 2015 08:29 AM
