Help with power windows and locks
Old Mar 8, 2018 | 08:25 PM
jcam6222's Avatar
I have a 94 extended cap v6 pickup that had the manual windows and lock doors, it now has power doors, I need to know how to make them,work for as wiring them up? Any help would be greatly appreciated!!! Thanks
Old Mar 8, 2018 | 09:39 PM
RAD4Runner's Avatar
A problem well-stated is almost solved. A picture paints a thousand words.
You have to put us in front of your truck. What door did you get? What model-year-engine-transmission-trim was the donor truck? What came with your door? Post clear pictures of your fuse blocks so people will see if your truck already has components (fuses, circuit breaker, relays) necessary to run a power door.
Does your truck have places for switches to control door?
How did you run the wires between the body and the door? What wires do you have in there?
What switches does the new door have? Post clear pictures of the switches and wires.
Old Mar 9, 2018 | 05:50 AM
scope103's Avatar
I assume you had factory manual doors, and managed to pick up a pair of doors with power windows/locks. The good news is you have the necessary switches and motors. But you're going to need to find a door lock control relay (size of a pack of cigarettes, above your left knee). http://web.archive.org/web/201106261.../8powerdoo.pdf They're still available, but you won't like the price of a new one. https://parts.lakelandtoyota.com/p/T...598035030.html
You'll also need the connector and wiring from the door to the relay; I'm guessing your doors were removed with wire cutters. You might be able find a salvage relay that was also removed with wire cutters, so you'll have the connector body.
Old Mar 11, 2018 | 04:41 AM
wyoming9's Avatar
Red face
Here is where prior planning comes into play .
Instead of a simple job now it will be so very interesting .
I would plan on getting the Toyota Electrical Wiring Diagrams for your truck
Or Lots of Fuses Fire Extinguisher Local Fire Company on Speed dial
Zpd426
Sep 13, 2012 04:30 PM
89red4x4yota
Feb 28, 2007 06:41 PM
MorphiasX
Dec 1, 2004 07:33 AM
