Help please 87 22rte
Old Nov 4, 2022 | 02:27 PM
87-4runner's Avatar
Help please. 87 22rte
adjusting the boost and didn't get the little C clip on the flapper for the boost valve.
Found the arm just resting on the turbo and the flapper wide open...
Fixed that now the check engine light is flash 5 times pause 5 times pause 5 times etc...
what the heck I've never had the CEL flash before???
Old Nov 5, 2022 | 04:58 AM
87-4runner's Avatar
took the o2 sensor off my other 22rte that I know is working and now it's flashing 11 times... pause 11 times and won't idle... smells like it's flooded.
Help!
Old Nov 5, 2022 | 08:35 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Did you do anything with the TPS? Maybe test with a meter to make sure you don't have any open circuits at the TPS, but adjust with the timing light method I've mentioned in the past.
87-4runner's Avatar
Got it fixed this morning
it was the cold start injector...
thanks Jim
sethm80
Nov 8, 2008 07:24 PM
SpecialScottie
May 17, 2008 07:15 AM
frm_808
Sep 5, 2007 11:52 AM
