help my highbeams stay on and wont go off.
Old Jul 28, 2009 | 10:48 AM
gary96360's Avatar
last night while i was wheeling i noticed that the high beams wouldnt go off even when i had the truck off. so now when i turn off the truck, i have to unhook the battery. you guys think its a bad switch or a bad connection, i have no clue how that switch works. any help will be greatly appreciated.
Old Jul 28, 2009 | 12:14 PM
bugs1961's Avatar
It may be the switch but it may also be the headlight relay. The relay is much easier and cheaper to replace and test so look under the hood on the passenger fender for the fuse block. The cover has a diagram that shows the headlight relay. Try tapping on the relay with a wrench and see if it's stuck. Next pull the relay out and test it. If the relay test good, get out the wiring diagram and test the turn signal/light switch. Good luck and I hope you only have to change the relay.
Old Jul 28, 2009 | 12:16 PM
gary96360's Avatar
i see the high beam light thing on the dash and the lights are on. the turn signals work, the switch to turn the lights on work. but the lights wont completly turn off
Old Jul 28, 2009 | 02:55 PM
gary96360's Avatar
to test the relay do you stick 12v to it
Old Jul 29, 2009 | 10:25 AM
gary96360's Avatar
i tapped the relay and nothing channged. if anyone knows anything about this kind of stuff please help
kawazx636
Oct 6, 2021 03:03 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
creecher10
Sep 30, 2015 03:27 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
beltcutter
Sep 30, 2015 06:14 AM
