help on my front end
Old Sep 29, 2010 | 02:15 PM
adamsfence's Avatar
my 94 is getting a motor change and the mech called me and told me to come look.....well the front passenger side axle fell off.... i knew i was going to have to replace the hubs but where the axle goes through the tire on the end there is a thread hole in the end. is this what holds the axle in or is there something else that is missing to hold it in?????
Old Sep 29, 2010 | 02:18 PM
xxxtreme22r's Avatar
there should be a c-clip in there as well. it goes right behind where the splines line up. that bolt is what holds the hub in place not the cv shaft.
Old Sep 29, 2010 | 03:41 PM
adamsfence's Avatar
can i just buy these parts.....or better yet anyone got pics of these so i can see what i need fsm don't have a pic or im not smart enough to find it
Old Sep 29, 2010 | 03:44 PM
adamsfence's Avatar
also when these things wear out do they normally fall out cause this hub on this side was stuck locked i may just need to change the whole thing out...ain't no telling how long the PO ran it like this
Old Sep 29, 2010 | 03:51 PM
do a search for rebuilding the hub on here, it will show you. also look in the FSM for rotor replacement.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
