Help me read my engine codes with my You Tube Video
Old May 5, 2008 | 04:56 PM
simpsons721's Avatar
Red face Help me read my engine codes with my You Tube Video
please help me read my engine code flashes
I would guess its 71 because my car feels overheated but my temp gauge reads normal
also give me tips on how to fix the problem
heres the video
http://www.youtube.com/watch?v=WvzATA_3Pck
[YOUTUBE]http://www.youtube.com/watch?v=WvzATA_3Pck[/YOUTUBE]
please tell me the code and the problem
I do have a link to a site with the error codes but i want to make sure im reading them right
sorry for my horrible counting
thanks
Old May 5, 2008 | 05:07 PM
Supra 4x4's Avatar
That is a 71 and it just keeps repeating until you remove the jumper wire or the code is cleared.
Old May 5, 2008 | 05:29 PM
abecedarian's Avatar
71- EGR gas temperature below pre-determined level during EGR operation or open EGR gas temp sensor signal.
Caused by:
EGR valve
EGR hose
EGR gas temp. sensor circuit (wiring)
EGR gas temp sensor
VSV for the EGR circuit
ECU
this post subject to change as more information gathered.
Old May 5, 2008 | 08:28 PM
js9924's Avatar
Caused by:
EGR valve
EGR hose
EGR gas temp sensor
ECU
x2 but....
Its probably the sensor but you need to take the EGR valve off and clean it out. It should slide smoothly if you push the valve up from the bottom, also clean the EGR vacuum modulator it has a small filter in it. The sensor is likely the issue you can try cleaning it sometimes it gets dirty, or you can push a 10k ohm resistor into the connector going to the temp sensor. This tricks the ECU into getting a good reading and will keep the code from returning.
sonic concepts
Aug 16, 2025 03:13 PM
BLRobertson
3.4 Swaps
Jul 10, 2015 04:27 AM
Vargntucson
Jul 4, 2015 12:15 PM
zytra
Jun 24, 2015 08:14 AM
94hiluxZE
Jun 22, 2015 10:42 AM
