Help me identify a part
Old Sep 1, 2020 | 03:16 PM
ncar93's Avatar
Question Help me identify a part
Hi Guys, i've got a 93 4wd pickup with the 22re. I recently did a swap rebuild and broke one of my brake lines connected to what I thought was a pressure equalization valve for the front brakes. I don't have a flair tool, so I brought it to the mechanics shop next door. They bypassed it completely, saying one of the fittings threads were ˟˟˟˟ed on the module. They thought it was an ABS module because it was plumbed into the power steering system? Either way, drove it to my place and had to depress the pedal all the way till it grabbed. I thought they forgot to bleed it, but just tried to bleed it and nothing is coming out from the front right caliper. I've attached the photo of the bypass and the module. Can someone tell me what the ˟˟˟˟ that thing is for and how to fix this properly?
WTF is this thing?
Thanks,
Nick
Old Sep 1, 2020 | 03:59 PM
scope103's Avatar
ABS Brake actuator. http://web.archive.org/web/201203160...17brakeact.pdf
Old Sep 1, 2020 | 04:54 PM
Paul22RE's Avatar
5 Year Member
Had no idea ABS was on a 93? What year did ABS start on the pickups? Was it an option at first or only on SR5s?
Old Sep 1, 2020 | 07:11 PM
ncar93's Avatar
Wow, I also didn't believe they had ABS back then, thanks for the info. Also sounds rare and expensive . Can it be bypassed like this?
Old Sep 1, 2020 | 08:08 PM
millball's Avatar
The Power steering actuated ABS was only 2 wheel ABS, and used a single sensor that used the rear differential ring gear as a tone ring.
By '94, or '95 there was all electric 4 wheel ABS that used tone rings on all 4 wheels.
Old Sep 2, 2020 | 07:45 AM
ncar93's Avatar
Is there another term to identify it? Im not finding anything useful on google searches about delete procedures.
Old Sep 2, 2020 | 08:52 AM
ncar93's Avatar
Found a link that worked; http://htftp.offroadsz.com/marinhake...17brakeact.pdf
William
May 26, 2021 05:24 PM
parks8760
Mar 26, 2013 05:04 PM
darkestskydiver
Oct 15, 2012 08:12 AM
Brend2b
Feb 2, 2010 11:42 PM
scenarioL113
Dec 1, 2006 06:31 PM
