help me get to work tomorrow
92 pickup. 22re. (see signature) i was driving back home for 3.5 hours.
2 hours into the trip i notice that it gets "bucky" when i throttle off and throttle on at 70mph. (keep in mind i have an aussie in the rear but its even more bucky than usual).
at 3 hours into the trip back home i hafta slow down for the toll both, so i push the clutch in and it dies. i coast engine off through the automatic payment toll booth. it starts back up and idles VERY low and rough. for the remaining half hour of the trip its still "bucky". at this point i am very low on gas. i drive another 20 miles and fill up at the gas station 1 mile from my house (and check mpg, 14mpg), and its still idling low, rough, and being "throttle bucky".
my gas mileage tonight was 14mpg, which is lower than normal. usually at 70mph its about 15.5mpg. city is usually about 17mpg.
for YEARS I have had a continuous check engine light on for a lean oxygen sensor signal. i've ignored this since i found out a replacement 02 sensor did not fix it.
before i left on this 3.5 hour journey away from home 4 days ago, here's what i did:
i haven't gone outside to do any more diagnosing, its midnight and 35 degrees outside. any ideas where to start?
- oil change. Quaker 10W-30 (oil is still full and clean)
- quaker oil filter (i would assume its still tight)
- topped off antifreeze (it took a whole gallon, typical for 3000 miles of driving on this truck)
- topped off washer fluid
- dynamic balanced my streetlocked wheels and tires. tough, but i did it.
- replaced a medium sized vacuum hose on the front of the valve cover. this vacuum hose is still attached and in good condition. thats the FIRST thing i checked while i was refilling at the gas station tonight.
You might want to pull your codes again and see if any new ones have shown up.
Any similarities in speed, RPM or gas pedal position? By that I mean is the "bucking" repeatable or avoidable by changing one of those factors?
The TPS could be worn or out of adjustment. Maybe a burnt spot at or around 70mph... but that would show up every time the throttle reached that position, if that makes any sense.
Have you thoroughly checked your intake hose for tears? They can be hard to see and deep in the bellows. The extra air will confuse your ECM and give your engine all kinds of operating issues.
Temp seem okay?
Just throwing out some ideas....
Temp seem okay?
Actually, RacingCameron reminded me of a problem I once had with a loose ground near the coil. Make sure all your related ground points are tight and clean.
When I had the ground problem, it would stutter when I hit a bump... so it was more intermittent than what you are describing.
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
i talked to some technicians at my old job and they pointed me towards the air flow sensor. i may try and find one for sale. anyone have one?
almost forgot , about the fpr when you turn the key to on position you should here the pump run for 3-5 seconds then quit.that means fpr is working right . if you ever turn key to on and pump keeps running without stopping your pressure regulator is definitely broken.hope you get the source of your problem
