Help me check my tranny fluid!
OK I have both Haynes and Chiltons manuals for my truck ('88 22R 4WD 5-spd), but neither of them are helping me check (and most likely fill up) the tranny fluid. They each say there should be a 17mm bolt on the side of my tranny that I take out and then can check the level. Well I don't see a bolt matching that description on either side of my tranny. So I took pictures of each side of my tranny hoping you guys could tell me which bolt I need to take out.
Here is the driver side:
Here is the passenger side:
I thought it was the right bolt in the picture of the driver's side, but that is a around a 15/16 bolt. Also, the left-upper most bolt in the passenger side picture looks promising, but it takes a torx to unscrew it, not a 17mm.
Rob
Rob
Iceman4193
Jul 15, 2015 04:48 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
