Help identify parts 94 4 runner 3vze 5 speed
Old Dec 13, 2020 | 02:56 PM
mmjohnston's Avatar
Old Dec 13, 2020 | 05:09 PM
scope103's Avatar
1 Banjo bolt for fuel line (though, I've never seen a plated one before),
4 Wire loom holders, in-board of two valve covers,
8 Exhaust manifold shield(I believe it is the drivers' side)
9 Shield on apron that holds flexible tire splash guard (passenger side) "PATCH, APRON. PATCH, FENDER APR. Side EXTENSION. (Front)"
11 Strut that holds up plenum, passenger side. "OBS. Stay, Surge Tank, NO."
5 May be radiator supports
Old Dec 22, 2020 | 01:12 PM
mmjohnston's Avatar
Thanks the help!!!
Old Dec 22, 2020 | 01:13 PM
mmjohnston's Avatar
I’m down to #6 and #11. Still can’t find where these go any help is much appreciated!!
Old Dec 22, 2020 | 01:26 PM
millball's Avatar
Isn't #6 the rubber boot for the clutch fork??
Old Dec 22, 2020 | 01:43 PM
scope103's Avatar
First, if you've identified the rest of the parts, you really should post here what they are. Sorta payin' it forward.
Next, I told what I thought #11 was, with a link to a Toyota drawing showing (exactly) where it goes. Do you disagree?
I'm less sure about #6, but it's probably the Boot, Clutch Release. https://parts.lakelandtoyota.com/p/_...112620060.html Again, look at the drawing; if that's not it, tell us why.
[As is so often the case, millball beat me to #6.]
Old Dec 22, 2020 | 05:39 PM
mmjohnston's Avatar
Edit sorry #6 is the clutch fork boot! Thanks
#2 is what I’m looking for still......🙏🙏
#11 is indeed the bracket that supports the plenum from the egr valve to the head. 👍🏼
Jasonsyd87
Jul 4, 2018 07:18 PM
Cdn-wilderness
Apr 10, 2016 06:57 PM
