Help identify leaky hose part
Old Oct 2, 2015 | 04:10 PM
Larz28's Avatar
This is my 88 22 RE engine. I'm leaking (I think its anti freeze) from a hose. Both ends have metal crimped attachments which is where I think its leaking from. One end goes into a vacuum tube and looks like it un bolts simply. The lower part seems to convert into a vacuum tube and goes into the steering box and comes back out. I'm not sure where it disconnects. Any help on identifying this part, buying a replacement, and how to swap it out, would be very helpful. Thanks everyone!
Old Oct 2, 2015 | 04:37 PM
voiddweller's Avatar
Looks like power steering hose to me.. Something like this
Old Oct 2, 2015 | 04:42 PM
scope103's Avatar
Looks like 44411 http://www.toyotapartsoverstock.com/...rimLevel=18406
Of course, you'll need your VIN to get the right one; you haven't given us enough information.
It SHOULD be leaking ATF, which is usually pink, and slightly "oily." Coolant should be light green, not oily, and have a slight sweet (?) smell.
Old Oct 3, 2015 | 05:22 PM
Larz28's Avatar
Thanks. I think that's it. I did notice some pink fluid at the bottom as well as anti freeze. Maybe I have 2 leaks. I'll get this one fixed and go from there. I appreciate the info. I knew I came to the right place.
DeathCougar
Apr 1, 2018 11:29 PM
delmert
Sep 30, 2015 04:34 PM
I8URSVT
Sep 3, 2015 11:42 AM
Gone Fission
Aug 24, 2015 04:59 AM
basfire
Aug 14, 2015 07:58 PM
