help with automatic to manual window conversion
Old Jan 11, 2012 | 10:05 AM
nicksmith18vt's Avatar
My power windows in my 86 turbo 4runner have been working on and off for the past couple of years so I decided to switch them to manual window cranks so that they will be more reliable. I bought the appropriate window regulators online for my 86 4runner. Today when i tried to install them only 2 out of the 3 bolt holes lined up, and when i bolted everything together and tried out my crank, the window went up at an angle. Has anyone else ran into this problem while converting their windows from power to manual?
Old Jan 11, 2012 | 11:39 AM
nmtoy's Avatar
I did this same conversion in my 86 4runner. Sounds like you need to rotate the regulator until all 3 bolts line up. All 3 bolts do line up.
Good luck
Robb
Old Mar 9, 2012 | 05:01 AM
rattlewagon's Avatar
Did you ever get your window issue fixed?
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poncho0206
Jul 10, 2015 06:21 PM
