help 22re runs rough
Old Apr 9, 2010 | 05:10 PM
86yoda's Avatar
Question help 22re runs rough
86 yota 22re runs rough in d&r auto i have replaced plugs,wires,cap,rotor,tps,temp sender,exhaust manifold,fuel filter no vacum leaks found,compression 2@145,1,3,4@160, pull plug wires while running 2,3,4 engine stumbles 1 idle doesn't change,not smoking out tailpipe,no water in oil,does run rich
Old Apr 9, 2010 | 05:17 PM
swampfox's Avatar
have you tried an old plug and plug wire on #1 to see if there is a change? one of them could be bad from the box.
Old Apr 9, 2010 | 06:07 PM
Levis Pennae's Avatar
I had the same issue with my 1986 22RE, I just changed the vacuum lines and it evened out right away.
Old Apr 9, 2010 | 06:38 PM
86yoda's Avatar
did swap plug on cyl 1 no difference there is good fire when hold wire away from plug, will try replace vacum hoses, what is best way to adjust air screw on throttle body
Old Apr 10, 2010 | 10:22 AM
rangerruck's Avatar
next would be a seafoam, or any other favorite, type cleaner treatment.
Colington
Mar 8, 2020 09:51 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
karbin
Jul 5, 2015 11:37 PM
