Heat Shield Location?
Old Jun 23, 2017 | 10:12 AM
philip64's Avatar
Can someone help with the location for this heat shield? It was labeled exhaust pipe heat shield, but we can't identify where it came from.
Thanks.
Old Jun 23, 2017 | 10:24 AM
thook's Avatar
on the frame rail sandwiched between it and the downpipe driver's side..... left of the transmission bellhousing. see how the bolt pattern takes a turn upward at the one end the two holes are close together? it's to line up with the upward bend in the frame rail as it leads towards the control arm.
not sure how you'll get it back it on there. there's a bunch crap in the way (like brakes lines..which i believe its what it's supposed to protect) when i tried to pull the shield off to do some exhaust work. if you're successful, far out!!
