Headlight switch,brights only
Old May 15, 2018 | 01:29 PM
mldave's Avatar
Pic if this link opens...lower left center....https://scontent-sjc3-1.xx.fbcdn.net...2b&oe=5B98C2FF
Old May 15, 2018 | 01:37 PM
L5wolvesf's Avatar
Great Thank you !
Now a question. There are 2 Phillips head screws in the pic - if you unscrew them does the headlight wiring and stalk separate from the rest of the combo switch?
If so does the turn sig side do the same?
Thank you
Old May 15, 2018 | 02:02 PM
mldave's Avatar
We didn't unscrew the headlight stalk,but checking just now on my extra switch the turnsignal switch(lever) is held on by two screws and a flat male plastic appendage that slides into a slot.
Old May 15, 2018 | 04:28 PM
L5wolvesf's Avatar
We didn't unscrew the headlight stalk,but checking just now on my extra switch the turn signal switch(lever) is held on by two screws and a flat male plastic appendage that slides into a slot.
So it sounds like the combo switch is a modular thing and you can replace the headlight portion (stalk et al) and/or the turn sig portion (stalk et al). That makes repairing one or the other a bit easier.
I'm just going to assume we're still talking about car parts here . . . right?
Old May 15, 2018 | 05:27 PM
  #25
mldave's Avatar
Yeah man,truck parts...on different years and models things are likely different.
Old May 16, 2018 | 09:01 AM
  #26
mldave's Avatar
@L5wolvesf,yes the two phillips screws that are pictured and another one on the stalk..but there is a thick wire going to the stalk from the wiring harness whick I guess would have to be spliced onto a new headlight stalk...this is for a 1986 Toyota truck 4x4 2.4 regular cab..combo switch Toyota part number 84310-35180...don't know what other years it fits.
seattlecard
Mar 28, 2015 09:47 AM
RobbinsRacing
Jun 1, 2009 08:25 AM
toyospearo
Sep 5, 2008 09:23 PM
redneck81toy
Apr 22, 2006 07:36 AM
rizzle1024
Mar 17, 2006 02:25 AM
