Headlight Relay Harness
Old Dec 10, 2012 | 10:34 AM
  #101
i'm very intimated with wiring , what color and length of wire do I need ? i want to tackle this unless some one wants to make me one
Old Dec 10, 2012 | 01:39 PM
  #102
scope103's Avatar
Richard: I hate to be discouraging, but if you are asking these questions, you will be better off having someone else do whatever wiring you're thinking of.
The wire has to be long enough to reach where ever you're going. The electrons can't see the insulation, and don't care what color you use. That's for your benefit, and you can pick Chartruse if you're into that.
But the gauge of the wire matters, as does the types of connectors used and the capacity of the relays. Most of which was covered earlier in this thread.
Stick to that with which you feel comfortable.
Old Dec 10, 2012 | 06:12 PM
  #103
Chartreuse is not my color maybe lavender , maybe I am over thinking it , just trying to gather as much info as possible
Old Jan 12, 2013 | 04:16 PM
  #104
'85 Yota's Avatar
Well I'm gonna give it a go and try to make my own. I'm a wiring nooooooob so we will see how it goes.
Old Jan 15, 2013 | 07:41 PM
  #105
'85 Yota's Avatar
Originally Posted by BMcEL
Assembled a headlight relay harness today. I drafted up a quick (don't laugh) schematic and got to work:
All cable is 12awg THHN except for the H4 pigtails...they're 12awg stranded but not THHN rated. I should have taken pics of the process but when I'm in go mode I just go. Here's the final product:
(2) 30A relays
(2) Female H4 pigtails
12awg THHN
Ring terminals for the battery connections
Butt connectors for the H4 pigtails
Male spade terminals for the factory H4 connector
Female spade terminals for the relays
1/2" wire loom
Electrical tape to wrap the loom
If you want to go all out, you could use a male H4 pigtail instead of male spades to plug into the factory H4 connector and relay pigtails instead of female spades to plug into the relays.
I ended up running a dedicated ground back to the battery (zip-tied to the loom every 6") afterwards. I figured with this much effort I might as well run the extra cable. Copper conducts better than steel and I didn't want ANY weak links.
Went for a quick drive tonight but I need to re-aim the housings. Even with the beams all over the place it's amazing how much brighter good halogens are vs. HIDs in halogen housings. One of these days I'll install a projector retrofit like this and go back to HIDs but for now halogen is fine. 55w/100w bulbs by the way.
Just wondering, do your highs turn off with your lows?
Old Jan 16, 2013 | 04:37 PM
  #106
BMcEL's Avatar
Yes. The lows stay on with the highs, however.
Old Jan 16, 2013 | 04:59 PM
  #107
'85 Yota's Avatar
Ok thanks. I made mine the other day and its a big improvement. How hot do your housings get with the 100w highs with lows?
Old Jan 16, 2013 | 05:12 PM
  #108
BMcEL's Avatar
Not too hot, but I have glass/metal housings. I wouldn't try it with plastic.
Old Jan 29, 2015 | 05:55 PM
  #109
elbrujo58's Avatar
(2) 30A relays
12awg THHN
1/2" wire loom
I cannot see the image of the schematic. has it been removed. It seems to be what I need. please help
JR
1uzRunner
63
Nov 10, 2018 03:58 PM
May-39
Sep 6, 2015 01:05 PM
LJR
Sep 5, 2015 06:02 AM
moparbay
Sep 3, 2015 12:48 PM
