Headlight problem
Old Dec 26, 2009 | 09:20 PM
Island_Yota's Avatar
Headlight problem
Having problems with my lights, I've only owned the truck for 3 weeks so im not very familiar with it, its an 88 4runner with a 22RE.. alot different compared to my 82 SR5.
My low beams quit tonight, high beams still function fine but the indicator on the dash no longer comes on, markers and signals are working fine. I checked the harness near the battery and it looks like someone replaced it, looks newer and has a p/n tag on it. My low beams/high beams have been some what erratic, one day a low beam will be out, the next its working fine, when I got the truck one of my high beams was dead but is working fine now.. When I turn my lights on I don't hear the relay working so that is the first thing I will check.
If the relay and fuses are good, What steps should I take to test the system? I guess a good place to start would be the switch.
Old Dec 26, 2009 | 09:26 PM
myyota's Avatar
check the combination switch, sometimes the contacts can get pitted from years of use. You can clean the contacts with a file and that usually fixes the problem.
Old Dec 27, 2009 | 07:10 PM
milehigheric's Avatar
Yeah start by checking the combination switch. The FSM shows continuity charts in order to test it. The lack of headlight bulb on the dash is probably just a blown light, unless there is some underlying issues in the harness itself.
Old Dec 28, 2009 | 04:48 PM
Bigblock's Avatar
All three of mine needed MF(multi function) switch restoration.
BigBlock
Old Dec 29, 2009 | 07:37 AM
leebee's Avatar
www.4crawler.com has a write-up on trouble shooting your light/switch issue.
lee
Old Dec 29, 2009 | 03:58 PM
not sure, the high beam indicator went away when the low beams died, the truck has 450,000km's on it. I havn't dug into it yet but when I figure out what it is il post up.
Old Dec 30, 2009 | 03:53 PM
Easy fix, the passenger side was a dead lamp, drivers side connector was shattered. Now I just need to aim them, they are WAY off.
ghostmoney
Jan 28, 2018 11:42 AM
Sep 4, 2015 09:27 AM
Jonny246
Jul 24, 2015 12:37 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
