Head Gasket Spray Adhesive?
Old Dec 19, 2006 | 09:10 AM
Bumpin' Yota's Avatar
Ok ive swapped my AC compressor and got the block prepped for the heads. I have the rock gaskets from engine builder, does anyone recommend I use any kind of spray on gasket sealer on the HGs?
Old Dec 19, 2006 | 09:14 AM
ewong's Avatar
Nope
But I used an OEM gasket
and it was a 22RE
Old Dec 19, 2006 | 09:36 AM
DudeBud's Avatar
copper coat
Old Dec 19, 2006 | 10:30 AM
stock87's Avatar
NO!
Because of the dissimilar metal and different expansion rates of the metals used in the head and block the gasket needs to slip a little. The gasket itself has some adhesives in the block side (I think). Either way, you want clean surfaces so the head can slip ever so slightly with cooling and heating.
Old Dec 19, 2006 | 11:00 AM
4runnerx3's Avatar
I know a guy who uses silver spray paint to make head gaskets stick, not sure what brand he uses, but he swears it works.
Old Dec 19, 2006 | 01:17 PM
dcg9381's Avatar
I've used stuff designed for head gaskets when dealing with composite gaskets. It shouldn't be necessary.
Old Dec 19, 2006 | 07:31 PM
mfxsupervillain's Avatar
If you're going to run a MHG don't use the spray, it breaks down the factory coating which defeats it's purpose but if youre running a stocker which is not metal, than a few even sprays are money.
Old Dec 19, 2006 | 08:57 PM
Morphine's Avatar
Originally Posted by DudeBud
copper coat
That's what I used. I couldn't remember until I saw the pic.
Old Dec 19, 2006 | 09:00 PM
toyota_mdt_tech's Avatar
Originally Posted by stock87
NO!
Stock 87 is dead on!
Old Dec 20, 2006 | 06:23 PM
spudrunner's Avatar
My buddy just rebuilt his 22 re and he told me that the gasket he got for the head in the rebuild kit was tacky. I really wouldn't recommend using anything on the gasket or surfaces.
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
