Hang used doors before or after painting?
Old Sep 28, 2007 | 10:22 AM
QuietGiant's Avatar
I bought a set of used doors for my 94 4door 4runner to replace damaged ones. It's been 30+ years since I did any body work or auto painting.
Should I prep paint the doors first (jams and inside) then hang them and finish the paint job or should I hang them both and then do all the prep and painting ? Any additional tips would be helpful.
(The used doors are white and I will paint cardinal red).
Old Sep 28, 2007 | 10:27 AM
Ringmaster's Avatar
Hang them 1st. To get the door gaps set.
You don't wanna scratch the new paint on the rest of the rig do you?
Old Sep 28, 2007 | 10:40 AM
jcfb's Avatar
If you're painting the entire rig a different color, I would say paint before hanging the doors, otherwise you get the doorjams a different color. However, if you're not repainting the entire rig, only the doors to match the rest of the truck, then hang the doors first.
But uhh... I doubt you can color match doors with a vehicle that has had 13 years of fading
Old Sep 28, 2007 | 11:00 AM
Tacoma750's Avatar
put them on, and make sure everything lines up. set all your hinges, anything that needs to be done. Pull off and paint em up. Install should be a breeze after that
chukarhunt
Dec 8, 2019 11:39 AM
jasonty
41
Dec 23, 2018 01:00 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
JookUpVandetti
Sep 11, 2015 09:41 AM
jjrbus
Aug 10, 2015 01:09 PM
