grinding noise possible wheel bearing
Old Jan 16, 2011 | 06:34 PM
4runner dude's Avatar
Exclamation grinding noise possible wheel bearing
waitin for something to blow up any minute
so besides my auto hubs on an 87 4runner going bad. about 2 hours ago driving home from work, i got a hard jerk to the right side. turned the radio down and you can here a slight griding. low pitched. from the front. still continued to grind some. then it pulled hard again to the right side. all correctable and only does it for about a second.
what would cause this?
its in 2wd and still grinds with the clutch in/ and in all gears. so its
not the engine.
not the transfercase
not the transmission
wat would cause this? wheel bearings? hub assembly?
cv shaft?
thanks
dillon
Old Jan 16, 2011 | 06:37 PM
mightymouse's Avatar
yes yes and yes along with brakes as well. Time to start taking stuff apart and figuring it out before you drive it any longer.
Old Jan 16, 2011 | 06:40 PM
yea i checked the brakes out when i got home. it was darm out and i didnt strip anything off. just checked with a light. it has new pads.
calipers might be going. or maybe rotors.
guess tommorow job. im hoping its brakes. it will be the cheapest fix if it is. mine as well replace hubs while im at it if its all coming off.
go with aisin manuals or warns?
Old Jan 16, 2011 | 06:48 PM
aisan hubs.
glowz825
Jan 25, 2022 09:28 AM
PlayAwhile
Jul 20, 2015 11:36 AM
mengquis
Jul 13, 2015 10:39 AM
mlavery85
Jul 12, 2015 10:33 AM
Gamble_STi
Jul 7, 2015 07:54 PM
