Good deal on gears?
Old Jan 25, 2013 | 05:19 PM
Edionne13's Avatar
Good deal on gears?
http://s1336.photobucket.com/albums/...er_media_share
So I've decided to get 5.29 gears and want yukon. This guy the 200 talked him into 195 and this maybe a dumb question but would it come with all the things I need to do the front swab from 4.10's?
Old Jan 25, 2013 | 05:38 PM
rattlewagon's Avatar
Link doesn't work
Old Jan 25, 2013 | 05:52 PM
dropzone's Avatar
Fossilized
i couldn't fix your code to get the link to work..
200 into 195?? sorry but that makes no sense to me.
if you rebuild a diff I would recommend a solid pinion sleeve but a clush sleeve and a master install kit.
Old Jan 25, 2013 | 06:22 PM
Edionne13's Avatar
Keep looking I guess. Anyone have any links for yukon gears or some other Gears for a good price?
Old Jan 25, 2013 | 07:36 PM
dropzone's Avatar
Fossilized
Old Jan 25, 2013 | 07:51 PM
ThatGuy1295's Avatar
Wow!!
Old Jan 26, 2013 | 12:05 PM
Co_94_PU's Avatar
Think it was this one, there are only two pics in the library
Picture says 550, not 200. A "Master install" kit should have everything. And as always don't throw nothing out till your done, and maybe not even then.
Old Jan 26, 2013 | 12:27 PM
Edionne13's Avatar
Exactly so that'd have everything for the front ha now the back
Old Jan 26, 2013 | 02:36 PM
Edionne13's Avatar
Okay so would it be okay to take out the 4:10 int 3rd member gears and swap in 5:29 with pinion and the ring? All the axles I've seen on cl been 488 and some people are selling for a grand...
Old Jan 26, 2013 | 05:41 PM
Double wow! You really should just start over.
Old Jan 26, 2013 | 05:58 PM
Edionne13's Avatar
Start over with what? The truck? Or... Not really understanding what you're trying to say here.. Sorry I'm a newbie
Old Jan 27, 2013 | 06:50 AM
93Xtra-Cab's Avatar
What he's trying to say is that he wants to swap in a 5.29 ring with 4.10 pinion gears into 488 differentials he got for a grand from the 3rd member of this forum
Old Jan 27, 2013 | 10:31 AM
Edionne13's Avatar
Exactly
Edionne13's Avatar
Wait now swap in 5:29 gears and with 5:29 pinion ring an taking out my 4:10. Is that possible?
Old Jan 27, 2013 | 10:46 AM
niall's Avatar
yes you can pull you're 4.10's and put in 5.29's. It's not as easy as just swapping them though. You'll need to set the backlash to spec, and it really is a good idea to throw new bearings and seals in while you're in there (master install kit).
Don't get hung up on yukon, there are plenty of good gear makers out there, equal or better than yukon.
Old Jan 27, 2013 | 04:41 PM
Edionne13's Avatar
What would you recommend I look at?
Old Jan 27, 2013 | 04:56 PM
Toyota~Boy's Avatar
Okay I just read through every post on this thread and to be honest lil buddy I believe you may wanna slow down with the typing a little bit and double check your post before posting it. Half the post you have made makes absolutely no sense. With that being said I believe that your wanting to change your gears from the factory 4.10's to a aftermarket 5.29. CORRECT
Check out EBay. There's lots of gear packages on there that include a master install kit. Read there reviews. If your unsure of one do a google search to get more info.
I hope you have someone to do this swap for you. No offense to you, but you sound like you have no experience on swapping gears. It's not a pull out, put back thing. Lots of specialty tools and knowledge are needed to do this.
Have you considered 4.88's if so there's alot easier solution then buying new gears. Most of your 89-95 V6 automatic 4Runners came with this gear package. So then if you found a set at a local salvage yard it would be a direct replacement for ya.
There's alot of things to consider when selecting a new gear package. It's not a cheap swap and a regular backyard mechanic probably can't change them.
Old Jan 27, 2013 | 05:00 PM
Edionne13's Avatar
I'm running 33's so I can run 35 in snow and stuff and 5,29's because of that I'm not running 4.88 at any point so I have a choice between tires. Brother in law knows how. And a buddie so ill be good in that. I have a pickup not 4runner
Old Jan 27, 2013 | 05:06 PM
Edionne13's Avatar
So I'm looking around on eBay I'm seeing it coming to about 800-1000 ?
Old Jan 27, 2013 | 05:08 PM
Toyota~Boy's Avatar
Pickup or runner..... That doesn't matter. There's know difference in the selected years between the diffs. I don't think you understood what I said.
What do you have exactly.....
Year
Make
Model
Engine
Tranny
Current tire size
Why are you hooked on Yukon. Have you considered a different brand. All info is needed
