getting BAD gas mileage
Old Oct 6, 2008 | 09:59 AM
4runnerguy's Avatar
I have a 1991 toyota 4runner v6 manual i get 275km from a full tank
all i have is 33x12.50 on 15x10
4.56 gears and i removed the egr and i did a isr mod what code be causing this
Old Oct 6, 2008 | 11:03 AM
ontario4runner's Avatar
i have a perfectly stock 4runner that gets 315km to a tank.. best i ever got was 400 and that was exactly 400km on the highway.. the 33s will kill it to, remember its taking power from you truck, changing how fast you are actually travelling.
but.. every mpg helps.. how is the truck running?
Old Oct 6, 2008 | 11:07 AM
904_runner's Avatar
The 33's
Mine is horrible too, i can't recall if it happend as soon as i put the trxus's on, but i don't think so. Before i ran some 33x12.50's that were bald and i was getting 18mpg and with the 33x12.50s trxus's on steelies im getting like 15mpg and the power went down dramatically.
Im leaning tworads teh tires, but if there is somthing else i should check im listening.
mine has had a recent tune up too, new plugs,cap, rotor, oil change to mobile 1, fuel filter, o2 sensor, cleaned the air filter
Old Oct 6, 2008 | 11:19 AM
Originally Posted by 904_runner
The 33's
after all that and its still terrible terrible gas mileage i would say its your tires
Old Oct 6, 2008 | 11:27 AM
904_runner's Avatar
yea, thats what i was thinking!
I need some 29" tires like norcrawler!
At least for daily driving! lol
Old Oct 6, 2008 | 11:39 AM
4runnerguy's Avatar
ya my motor is got 238km it runs ok it does a good klicking sound when its cold out. and i am running it lean i did a little afm mod
Old Oct 6, 2008 | 11:49 AM
Slowstrike's Avatar
This may sound stupid but If you take it out on the trail alot make sure one of your hubs is not staying locked.
I had a hub spring break, went out had it in 4wd and it never disengaged. I dident notice, drove it for a over a month before I realized I had one locked. I used the other hub to unlock it for now.
Probly not the case but never hurts to check, it split my gas milage nearly in half.
Old Oct 6, 2008 | 11:57 AM
904_runner's Avatar
good thinking! thanks
Old Oct 6, 2008 | 12:27 PM
abecedarian's Avatar
keep an eye on the tire pressures too.
leaning out the fuel mix can have a negative effect on mileage if taken too far. the ECU will use the O2 sensor to bring the mix back into spec with the AFM mod mentioned.
Old Oct 6, 2008 | 12:36 PM
904_runner's Avatar
i have trxus running at 32psi. Mine seems like it is running a little rich too. I have the timing advanced from 10 degrees to 12. but thats all the toying ive done
Old Oct 6, 2008 | 01:47 PM
4runnerguy's Avatar
my psi is 35 all around and i check my hubs every morning just in case my friends decide to pull a stupid one.
but the thing is i can still smell the richnus and i do have a new Co2 on and a magnaflow cat and a cherry bomb
Old Oct 6, 2008 | 02:57 PM
Jay351's Avatar
Hmm, thats pretty low. I used to get around 300km to a tank back in the winter time with a untuned engine..
I have gotten up to 21mpg hwy with my truck with all its mods.. Average mixed driving is around 17mpg. Still higher then what you got.
Make sure you take into account the mileage difference since you have a mis-matched tire/gear ratio.
When have you done a tune up? Im talking FULL tune up, what brand parts you using? Lay off the skinny pedal! Coast as much as you can too
Old Oct 6, 2008 | 05:24 PM
4runnerguy's Avatar
thats what i have been doing taking it easy. also soon i got to do a oil change.
i did a tune up 3 weeks ago and i go dealer items on it
Old Oct 6, 2008 | 09:10 PM
904_runner's Avatar
okay i found my problem i think!
LIke i mentioned eariler, my power and mpgs went down dramatically.
well on the way home today i was in 2nd gear on a two lane highway, had it floored, and no power, couldn't get above 45 mph. so i called around to people i know and my grandfather suggested my cat was clogged. So i unbolted it for now and walla, its fun to drive again! Off to get a new cat tomorrow!
Oh and btw, with the clogged cat, this last fillup i managed 13mpg's'
so when i first put my lift on i was getting about 18mpgs or so, and it dropped to 13. I bet it goes back up.
Old Oct 6, 2008 | 10:24 PM
Jay351's Avatar
Haha, I bet it will too!
Old Oct 6, 2008 | 10:29 PM
904_runner's Avatar
Lol, if not id be kinda mad! Lol
Old Oct 7, 2008 | 03:10 AM
gte718p's Avatar
if your cat was clogged it might be time for a full tuneup. And 4.88 or lower are worth it. I can't really say what caused it but a tuneup and 4.88 I went from 9 mpg -22 mpg
Old Oct 7, 2008 | 04:35 AM
4runnerguy's Avatar
wow that is amazing 9 to 22mpg ya see my cat is about 2months old
Old Oct 7, 2008 | 07:44 PM
904_runner's Avatar
well, original cat if that matters with 253,000 miles???
and i did, cap, rotor, plugs, wires, o2 sensor, fuel filter, oil, air filter.
Hey i actually passed people up this 2 way highway uphill for the first time! With ease too!
Old Oct 7, 2008 | 07:55 PM
hmm... I spent about 640 bucks for a round trip from home to Beaumont Texas and back... about 3000 miles... with an average speed of about 75-80.
how does that work out for mileage? about 18?
