GEAR QUESTION, I don't no what I have!!
Well here we go. I have a 95 4x4 4runner, and I'm not sure what gears I'm running. I'm running 31" tires on it now, but thinking of moving up to 33" but I want to make sure I can do this with the stock gears. Does anyone no the type I' running?
There are a few places that you can look it up if you know the axle code. A quick search on here should find one.
Or for a definite answer just jack up one tire, spin it 2 times and count the # of times the drive shaft turns. About 3 and 3/4 is 3.73, slightly under 4 is 3.9 something, slightly over 4 is 4.1, about 4 and a half is 4.56, etc. If you want to be more accurate turn the tire 20 times and divide the driveshaft turns by 10.
you probably have 4.88's like me! look here to see what you have..
http://www.brian894x4.com/Gearratiosanddiffs.html
You eithere have 4.56 or 4.88. There are a few other possible but NOT very likely. If you are a v6 5speed and STOCK 31" tires you have 4.56, if you have the auto you have 4.88. If by somehow you have a V6 and 235/75 tire options, which is EXTREMELY rare by '95 you coud have 4.30
OR look at the door jam id plate. There is a 4 digit code for the axle. First will tell you the size, second and third is gear ratio and fourth is number of pinons. The first and last numbers ONLY apply to rear axles regardless of 4x4 or not.
First digit codes:
A 138mm
B 145mm
C 6.25"
D 6.62"
E 7.1"
F 7.5"
G 8"
H 9"
J 9.25"
K 9.5"
L 10.5"
M 12.5"
N 13.5"
P 14"
Q 12"
R 162mm
S 6.38"
T 6.7"
U 6"
V 10.6"
W 15.5"
X 142mm
Y 158mm
Z 202mm
*front wheel drive cars will not have this number*
Scond, third digit codes:
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70
06 3.889
07 3.90
08 4.111
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556
26 5.571
27 3.364
28 4.30
29 4.10
30 3.727
31 3.90
32 6.591 OR 4.807
33 7.503 OR 5.583
34 6.781 OR 4.786
35 7.636 OR 5.60
36 4.778
37 3.583
38 3.417
39 3.154
40 5.375
41 3.308
42 6.500
43 3.550
44 3.214
45 3.533
46 2.928
47 3.944
48 3.356
49 3.729
50 3.400
51 3.736
52 3.722
53 3.250
54 3.941
55 3.333
56 2.821
57 4.058
58 3.238
59 3.234
60 3.519
61 2.724
62 2.892
63 2.655
64 4.312
65 3.837
66 3.071
67 3.526
68 3.095
69 4.176
70 5.857
71 2.962
72 3.949
73 4.285
Fourth digit code:
2=2 pinions
3=2 pinons+limited slip
4=4 pinions
5=4 pinions+limited slip
Unlike the above link what I have posted applies to ALL Toyotas regardless of year or model
First digit codes:
A 138mm
B 145mm
C 6.25"
D 6.62"
E 7.1"
F 7.5"
G 8"
H 9"
J 9.25"
K 9.5"
L 10.5"
M 12.5"
N 13.5"
P 14"
Q 12"
R 162mm
S 6.38"
T 6.7"
U 6"
V 10.6"
W 15.5"
X 142mm
Y 158mm
Z 202mm
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70
06 3.889
07 3.90
08 4.111
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556
26 5.571
27 3.364
28 4.30
29 4.10
30 3.727
31 3.90
32 6.591 OR 4.807
33 7.503 OR 5.583
34 6.781 OR 4.786
35 7.636 OR 5.60
36 4.778
37 3.583
38 3.417
39 3.154
40 5.375
41 3.308
42 6.500
43 3.550
44 3.214
45 3.533
46 2.928
47 3.944
48 3.356
49 3.729
50 3.400
51 3.736
52 3.722
53 3.250
54 3.941
55 3.333
56 2.821
57 4.058
58 3.238
59 3.234
60 3.519
61 2.724
62 2.892
63 2.655
64 4.312
65 3.837
66 3.071
67 3.526
68 3.095
69 4.176
70 5.857
71 2.962
72 3.949
73 4.285
Fourth digit code:
2=2 pinions
4=4 pinions
Hey, bear80, that info is awesome. I saw something like this on the net sometime ago, but no where near as detailed as this. I think this info needs to be stickied or in the mod section or something. Great post!! :bigclap: :bigclap:
TURBOrunnerNM
Jul 22, 2015 11:01 AM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
