gauge problems
Old Jan 19, 2011 | 03:20 PM
mgood's Avatar
gauge problems
Ok here is my problem and before you guys jump on me for not searching first, I only have phone internet and the search engine does not work. My gas and temp. Gushed come on when they want to but after they start to work they stay on till I cut off the truck. I don't think it is a ground issue because they would cut in and out but I could be wrong. If it helps it is an 86 with a 22r
Old Jan 19, 2011 | 06:27 PM
myyota's Avatar
I would check the wiring harness were it plugs into the back of the gauge cluster to make sure its plugged in tight, also check and tighten all of the screws and nuts on the back of the gauge cluster. Also check your grounds.
Old Jan 19, 2011 | 06:55 PM
mgood's Avatar
Thanks I will have to check that this weekend along with pulling top of Carb.
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Nickyodaman
Jul 27, 2015 12:13 AM
Logz808
Jul 26, 2015 07:09 AM
Poncho0206
Jul 10, 2015 06:21 PM
