gasket sealant needed?
Old Oct 4, 2010 | 11:38 AM
DROPT's Avatar
is it needed on the timing chain cover? and if so what kind?
do i need it anywhere else? im replacing the head gasket and timing chain. so wondering if and what gaskets need sealant. thanks guys
Old Oct 4, 2010 | 12:10 PM
andykrow's Avatar
don't know if its needed but on the timing cover I've used a gasket with toyota black FIPG sealer. You can buy it at the dealership for like 15 bucks and you want the black one since it's specifically for oil. (I think the other color is for transmission fluid) I used this on two timing cover jobs with less-than-stellar surfaces (i.e. I didn't clean off the old gasket too well...) with no leak at all either time, first try. That stuff is amazing.
Someone else will chime in on the head gasket but according to the FSM (for a 22re) you use a tiny bit of FIPG where the timing cover meets the block and nowhere else.
Old Oct 4, 2010 | 12:11 PM
Solomon8's Avatar
I put Black RTV on the corners to hold the gaskets in place, and I had no problems. Who manufactured the timing kit? I ask this because, you get what you pay for.
Old Oct 4, 2010 | 12:15 PM
Solomon8's Avatar
I replaced the timing chain leaving the head on and greased up the head gasket with RTV, so it slid in place.
Old Oct 4, 2010 | 12:31 PM
andykrow's Avatar
^^ same thing here.
voiddweller
19
May 2, 2016 09:10 PM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
