gas leak at idle only?? info needed
Old Oct 15, 2009 | 11:34 AM
securekey's Avatar
My 91 pickup will leak fuel if I sit and idle for a while. But it does not leak all the time.. just at idle.
here my random thoughts
1. could the fuel pump be sending too much gas (it gets used when driving but not at idle?)
2. I have read there is a 'breather hose' could fuel come out of it?
Lastly... how should i go about diagnosing the problem.. thank you.
Old Oct 15, 2009 | 11:37 AM
malteserunner's Avatar
3vze, 22re, or 22r?
Old Oct 15, 2009 | 11:50 AM
securekey's Avatar
sorry thought that was in my sig... 3vze
Old Oct 15, 2009 | 01:36 PM
idanity's Avatar
check my post here for my resolution
it started very slow, as ya drive, the vapor is easily un-noticed w/windows down, or driving.
i found my leak using my g.f.'s mirror and a highbeam flashlight.
it would drip every second, and not a lot. but luckily enough for me to find it. and know it was there,,,
place the mirror on the firewall, and shine the light on the mirror too...find that round dampner and watch it..
really pretty easy to fix...(hopefully thats it)
i heard it starts out slow, and can become severe anytime (and cause a fire that may be very difficult to put out)
Old Oct 15, 2009 | 02:57 PM
securekey's Avatar
Yes I have read about the dreadful dampener... but my leak is actually from under the skid plate on the tank.. should have mentioned that too..
Old Oct 15, 2009 | 04:51 PM
yodta's Avatar
if you kinda know the area, I'd pull the tank armor off and look around. might just be a rotted hose.
don't worry, the tank protection doesn't actually hold the tank in place. it's just a shield.
it could also be coming from the tank drain plug, too.
you should see a path. it'll probably look like an unusually clean or dark spot, kinda like lube overspray on the frame.
Old Oct 15, 2009 | 05:59 PM
securekey's Avatar
I will pull the skid on Saturday... I thought for sure it was holding up the tank... (coming from the jeep world ) I will poke around and see what I find...
JF9243176
Oct 8, 2017 04:21 AM
BigArt70
Jun 30, 2015 09:51 PM
JF9243176
Jun 24, 2015 04:53 AM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
