Fuse locations, diagrams, etc. (especially Horn)
Old Oct 29, 2009 | 02:19 PM
BlackNite3's Avatar
Greetings,
I'm officially a YotaTech newbie now, but just bought my second 1st generation 4Runner. This one is an '88 V6 with an auto. It's a pretty clean truck which naturally needs a little more TLC than originally anticipated.
I just failed the NC state inspection because the horn wouldn't work. I never even thought to try testing that. Oh well. I'm stuck indoors now but I did manage to find a small fuse box under the dash on the driver's side, but no diagram of what fuse does what. Is the Horn fuse in this location? I figure I'll start with the fuse and trace the fault from there.
And I'll need to replace the incorrect late model "small" fuses with the correct "normal" size blade fuses. Yeah, I was disturbed to see them wedged in there. I think I've got a few electrical "repairs" to repair, including the ignition switch (wired into a push button. clean, but rigged), and the rear window (toggle switch ).
Any suggestions for pinpointing the horn fuse? The owners manual is missing.
Thanks!
Old Oct 29, 2009 | 02:23 PM
weaselman's Avatar
you could always buy a chilton or a haynes manual from an auto parts store. they both have wiring diagrams in them. theat could help.. or online someone has to have a FSM..
Old Oct 29, 2009 | 02:29 PM
4Crawler's Avatar
Would help to know what sort of vehicle you are asking about. I have some fuse info. from my '85 4Runner on the web page below:
- http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
Old Oct 29, 2009 | 02:42 PM
BlackNite3's Avatar
I should have done a search first. I think I may have found a pdf of a factory service manual for the '88 4Runner. I actually have the Haynes manual but didn't see a fuse diagram in there, and the wiring diagram is just split into early or late wiring. Haynes is a good starter manual, but not that great for specifics (in my opinion).
I also found several threads here on the same subject. I should be set. Thanks for the help though!
Patrick
Old Oct 29, 2009 | 02:44 PM
BlackNite3's Avatar
That's a great resource! Thanks!
Old Oct 29, 2009 | 02:48 PM
BlackNite3's Avatar
Originally Posted by 4crawler's link
The "A" bolt on the driver's side actuates the "shell installed" interlock switch for the rear window relay
Double score! I'm missing most of the bolts for the top and the window doesn't work. I think I know why
Old Oct 29, 2009 | 02:52 PM
milehigheric's Avatar
The fuse is in the engine bay fuse box
ghostmoney
Jan 28, 2018 11:42 AM
montanatruck
Feb 26, 2017 07:07 AM
theking11863
Mar 19, 2016 09:36 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
rushw
Jul 18, 2015 01:46 PM
