Fuel Pump
Fuel Pump
I am running a 22RE, do I have to run a fuel pump in the tank, or can I run an external pump? I guess my question is more on what is the pressure of a stock fuel pump and the gallons per hour is moves? Thanks
You can run either as long as there is adequate pressure for your application.
Some people do run in-line pumps for port injected 22REs.
You'll need a pump that can provide over 40psi. Over 40 the regulator can it its job. (normal EFI -not TBI- pump will work fine)
No idea on volume. You'd need to test the stock pump at specific pressures. RC Engineering may have the specs.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
