fuel line order
Old Aug 25, 2015 | 03:57 PM
Duppie007's Avatar
fuel line order
I put a new gas tank in my truck (1988 V6 sr5 pickup 4x4 xtra cab) and need to know the order of the fuel lines. The send I have on because that only goes to one spot, I mostly need to know where the other lines attach to?
from the back of the truck there is the fuel send, then fuel return on the fuel pump housing unit and then a third hose attachment on the tank. Of the last two, where do I plug in the line from the EVAP charcoal cannister?
And yes in the future I will label all lines and such.
Cross posted in the newb section with zero thread views and I need this done before tonight.
Old Aug 25, 2015 | 05:09 PM
Duppie007's Avatar
anyone? Or is this place worse than bikeforums?
Old Aug 25, 2015 | 07:39 PM
scope103's Avatar
Gosh, you waited one whole hour! I would demand my money back.
http://personal.utulsa.edu/~nathan-b...91fueltank.pdf
By the way, you're more likely to get help (at all) if you proof-read your posts. "The send I have on ..."?
Old Aug 25, 2015 | 11:51 PM
wyoming9's Avatar
Red face
I guess the lines were removed when you got the truck.
Quite easy to figure out before installing the fuel pump bracket and fuel pump .
I am curious what is a send line??
sandyota
Feb 4, 2021 11:16 AM
Poppie51
Jul 23, 2015 05:03 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Poppie51
Jul 16, 2015 06:16 PM
Fundy Rider
Jul 16, 2015 01:35 AM
