Fuel line fittings
Old Sep 20, 2009 | 11:56 AM
Evan Houston's Avatar
Fuel line fittings
well its been 4 times now taking my gas tank out and i was wondering if i can get some help on how to hook up the main fuel line to the fuel pump hose so theirs no leaks. i know theirs a proper fitting that threads in to the fuel pump hose but i was wondering if i can just cut the brass line behind the fitting with pipe cutters and flair it and just clamp 1/4inch hose on? i would rather do that then risk pinching the brass line trying to unthread the fitting. thanks
Old Sep 20, 2009 | 01:53 PM
Flash319's Avatar
I just cut the steel tube and slid the hose on and put 2 fuel injection clamps on each end. The pumps on these engines hardly ever go over 35-40 PSI. I have never had a problem.
Old Sep 20, 2009 | 02:41 PM
85excab's Avatar
ive been using fuel injected rubber hose with 2 clamps on each end for 5+ yrs now, and havent had any problems, the pressure is low enough that it doesnt hurt. but it is 5/16 for the high pressuer line, 1/4 is too small and starves the engine for fuel at high rpms.
Old Sep 20, 2009 | 07:42 PM
what fittings do you use to adapt it from 1/4 fuel line to 5/16? does the high pressure line have to be 5/16 all the way back past the fuel filter?
Thanks for the help!
Old Sep 21, 2009 | 07:34 AM
Ed in Maine's Avatar
I believe I did 1/4" flexible EFI rated hose all the way. Double clamps on anything that does not have a slight flare/bubble on the tube end. i.e. double at the tank and fuel rail input, single at the filter. I just used a napa $5 steel filter with the right ins and outs. Has been >1yr, no issues.
Old Sep 21, 2009 | 07:47 AM
24Runna's Avatar
1/4" FI hose is too small. 5/16th's is the size I used when I cut the lines for my fuel filter. Now I can change the fuel filter in 10 minutes. I also used 5/16th's when one of my lines rusted out.
Old Sep 21, 2009 | 07:49 AM
24Runna's Avatar
No adapters, the tube slides over the metal pipe. Then use a screw clamp. Honestly I would just do the fuel filter now while you have the chance. Get it over with.
Old Sep 21, 2009 | 08:26 AM
I just rechecked and it is 5/16 that I ran all the way. I ordered 10ft on line and even with shipping was still cheaper than napa. Think it was some $2.50/ft there!
Ed
Old Sep 21, 2009 | 04:57 PM
well the metal pipe is tight with 1/4 inch hose on it . now if i put 5/16 on it will it leak? i did replace the fuel filter but i was wondering if i have to run the 5/16 hose all the way to the motor? the fuel line that the original owner installed is 1/4 inch so i went with that not knowing that it will starve the motor at high rpms. will this do any damage to my motor or just cause lack of performance at higher rpms?how much of a power difference will i notice? if its a lot of power loss i will take the tank out for th 5th time
Thanks a lot guys i really appreciate the help cheers
Old Sep 21, 2009 | 08:38 PM
85excab's Avatar
its a huge loss for power, cant go over 3,000 rpms with out sputtering
Old Sep 22, 2009 | 04:19 PM
well i haven't noticed sputtering over 3,000 rpms but if its a huge loss of power then i have to swap the line for 5/16 and take the tank out for the 5th and last time. so i obviously have to run the fuel line all the way past the fuel filter and to the motor to keep the fuel flow consistent right? because the previous owner ran 1/4 from the motor to the out side of the fuel filter. now how hard is it to run the line to the motor? i haven't followed the line all the way back to the motor yet. i can't see y it would be to hard seeing that im working on a toyota lol.
Thanks again for the help guys
Old Sep 22, 2009 | 04:22 PM
I camped mine right onto the fuel tube beside the passenger header. I had to pull it back with a ziptie to keep it off the header now that I recall. The 5/16" line was fairly tight, no leaks what so ever.
Old Sep 22, 2009 | 05:00 PM
Thanks so much!!!
Cheers : )
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
87turboPA
Jul 9, 2015 05:58 AM
