fuel door lockcylinder
Old Nov 25, 2013 | 12:51 PM
bbrideau's Avatar
Is the lock cylinder on the fuel door the same as the ones in the doors?
Truck in question is 88 4runner sr5, 22re if that makes any difference.
I cna find door lock cylinders but no fuel door cylinders. Can't seem to find a kit either with the door locks and ignition cylinder all keyed the same.
Note: i have not talked to toyota yet about a lock set, not sure if they have them still or how much they would cost.
Old Nov 25, 2013 | 01:29 PM
wyoming9's Avatar
Red face
Decide just what key you want to unlock everything pull all the lock cylinders.
Go to your local lock smith
Get all the cylinders keyed the same.
I doubt Toyota has a full lock set it would be one piece at a time. then expensive.
Old Nov 25, 2013 | 05:01 PM
1993 4x4's Avatar
My 1993 is. The ignition, doors and fuel door are all the same
Old Nov 25, 2013 | 05:11 PM
slacker's Avatar
I think what hes asking is if the cylinders are interchangable ?
and no a direct replacement , but can be made to work
I have a couple of complete truck lock sets , but no 4runner sets
Old Nov 26, 2013 | 07:31 AM
fdp101452's Avatar
I bought a lock set for my 90 pickup from Toyotapartscenter.net about 2yrs ago, so you may still be able to get oem.
Old Nov 26, 2013 | 09:00 PM
4digger's Avatar
When mine broke I went to Home Depot and bought a cabinet lock and it fit in there and works perfectly fine. however if you don't want to take the cheap way out heres the lock for your runner. http://www.ebay.com/itm/Toyota-4Runner-Pickup-Gas-Fuel-Door-Lock-Cylinder-with-Keys-Factory-NEW-/161156622422?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AToyota%7CModel%3APickup%7CYear%3A1988&hash=item2585aee856&vxp=mtr
Old Nov 27, 2013 | 01:39 AM
RAD4Runner's Avatar
Cylinders do not look interchangeable.
Old Nov 27, 2013 | 08:40 AM
bbrideau's Avatar
Didn't think they were interchangeable, i didn't want to have to take them all to locksmith and have them re-keyed, not that its expensive just a pain as i live in small town thanks for the ebay link on the gas door lock.
I havn't looked at removing the door locks but i would hazard a guess and say that on the inside of the doors theres tabs on the lock cylinder to remove it? or is there more to it then that?
Old Nov 27, 2013 | 09:08 AM
RAD4Runner's Avatar
Removing Door Lock Cylinder Simple To Do
Very easy to remove. See FSM for for procedure for accessing door.
Tools needed:
  • Rag. Yes, rag to remove clip that holds door crank,
  • Philips screw driver for a few screws.
  • Rope or good friend with a beer. He holds beer with one hand and the door panel up with other hand at window level while you work
  • Very fine long-nose pliers for removing and re-installing clip-ring that holds door lock mechanism to cylinder.
  • 10-mm socket & ratchet, in case you want to remove window regulator to lubricate/inspect
  • Clean floor with no cracks/grate/etc so you do not drop and lose clips
  • Most importantly quick and sharp eyes to see where clips went flying to - LOL!
Supplies:
  • MP Grease. Not for door cylinder but good idea to lubricate the window regulator while you're in there.
  • Oil/Silicone sparay to lubricate door cylinder
  • Some plastic material or tape to mend waterproofing sheet if needed. I use Polypropylene document protector.
Happy Thanksgiving, guys!
Old Dec 1, 2013 | 10:20 PM
SX200's Avatar
I looked at installing a lock.
I poped a magnet behind the flap just above the lock hole.
Keeps it closed and was cheap, I also put a rubber grommet in the hole made it look tidy.
westonian18
May 1, 2020 06:38 AM
TDonkey
Jul 26, 2015 10:14 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
94yotaky
Jul 23, 2015 07:50 AM
